Results 1 to 10 of 11
Thread: castrol gtx magnetec vs stnd vaux oil?
    Aberdeen
    Default castrol gtx magnetec vs stnd vaux oil?
    As above. Does castrol gtx magnetec provide any benfetis over the standard GM oil? Is it worth the extra cash?
    not really... i'd reccomend just sticking to the VX oils.. the cars are designed with it in mind, and VITALLY you MUST use VX oil's for their low sulphur content if you have a diesel with a DPF..
    Aberdeen
    Dont have to worry about the DPF as it is a petrol (1.8 VVTi). Planing on doing an oil change this weekend, and been offered 10ltrs of Castrol GTX Magnetec from my neighbor for nothing. It is rated as 5w30 so i am assuming it will be allright?
    if it's free, and as it's going into a petrol, then yes it's fine, BUT don't leave it in beyond 10,000 miles as it's not a longlife oil
    Aberdeen
    Cheers very much, Normally change the oil every year so that should be fine.
    Many Thanks
    Regular Member johnnyg's Avatar
    May 2007
    manchester
    sorry to hi jack but hoe do you get the oil filter off on the vvti engine never seen one like that before ?.and how much are they please anybody
    Belfast
    You'll need a oil filter socket, think it's either 32mm or 38mm.
    Unscrew cap, replace the paper element AND the o-rings (new ones supplied with the filter), then refit.
    Aberdeen
    Hi
    Basically as above, looking at the engine it is on the right hand side facing the front, about half way down the engine block. It has a black rubber cap with a hex nut on the top. I will get a picture for you tommorow, its a bit on the dark side at the moment. As for the part number I really dont know, I have asked autovaux.co.uk for it. As for price it will proberly be around the £5 mark.
    Hope this helps
    halifax
    Default Oil filter.
    Hi I have just done the oil and filter on my 2007 1.8 vvti needed a 27mm socket for the filter
    Aberdeen
    Good going. Do you have the part number for the oil filter?
  1. Castrol Magnetec Oil on special at Halfords
    By John LE in forum General Motoring Chat
    Last Post: 5th April 2012, 16:03
  2. CASTROL GTX on offer!!
    By victorM in forum Detailing and Car Care Discussion
    Last Post: 5th January 2012, 22:59
  3. castrol magnetec
    By tyler boy in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2011, 00:01
  4. F40 gearbox oil - use castrol SMX-s!
    By mozzer99 in forum Engine & Drivetrain
    Last Post: 12th March 2011, 11:25
  5. Tesco's got Castrol oil reduced.
    By john1 in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2010, 06:20
