Results 1 to 10 of 13
Thread: dodgy egr i think!
    Regular Member littlesxi's Avatar
    Oct 2007
    derby
    Thumbs down dodgy egr i think!
    does any one know if a egr valve has anything to do with the temperature that the car is running at?has anyone got a how 2 on taking one off and cleaning it,that is if it is a diy job?
    Oct 2007
    derby
    wheres nutron when you need him!
    Regular Member Ian's Avatar
    York
    Mines gone at the mo, but runs fine temp wise. Dont know the ins and outs of taking it off though.
    Regular Member Bullylad's Avatar
    Bolton
    the EGR won't control the running temp... thats the job of the thermostat...If it's running cold then replace the Thermostat first before condeming the EGR valve..
    Oct 2007
    derby
    its running hot,between about 80 and 90 degrees,will that still be a thermostat problem because it used to run at around 75.when the car gets hot i start having problems with the engine juddering and smoke from the exhaust.any ideas?
    80 to 90 is the correct range... 75 is too cold... so it's not the thermostat...
    any error codes?... what colour is the smoke?
    Oct 2007
    derby
    took it in to vx and the only code it through up was for glow plugs(which look like a right pain in the a**e to get to)when you put your foot down it kicks out loads of smoke which is white or light grey i think,i thought i would have had the spanner light on with it running so badly
    Oct 2007
    derby
    the smoke coming out of the back is black actually sorry to misinform,any ideas,has anyone taken their egr valve off before to clean it/change it/look at it?
    South Central England
    10 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Black smoke usually indicated over fueling, this might be a MAFS problem. Do you have a remap or tuning box? My car runs 84-85 Deg when cruising as have all the 1.9CDTIs I have driven.
  1. bit dodgy
    By sig num in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2010, 21:58
  2. dodgy MAF
    By craigbarlow18 in forum Engine & Drivetrain
    Last Post: 2nd October 2009, 08:29
  3. its gets even more dodgy!!!
    By big rich in forum General Chat
    Last Post: 21st August 2009, 19:18
  4. hid kit dodgy?
    By duncan2008 in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2009, 17:32
  5. Dodgy Ref
    By AJA in forum Comedy & Humour
    Last Post: 11th February 2007, 04:51
