Results 1 to 10 of 13
Thread: CD30 & Parrot CK3100
    Sheffield
    Default CD30 & Parrot CK3100
    I Have A Ck3100 to fit into my 07 SRI150 Auto, It came with a set of SOT LEADS, But I cant get it to the Blue Tooth Kit to Turn ON.
    Dose the vectra have a ignition live in the head unit loom? as the stero will power up with out the ingnition on?
    Do i need to pick up 12 Ing/Per live from elsewere?
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    i know on mine we took a live feed from the cig lighter
    Here, there and every where!
    I took a live feed from the glovebox light and a switched feed from the lighter socket
    Feb 2006
    Dorset
    Live comes from the rear of the headunit , you needto get a switched ignition from the cigar lighter to tell the kit to power on/off
    Sheffield
    How did you get the lighter out as I can remove all to the trim parts but the cig liter wont lift out nither will the casing under the ashtray
    Cirencester
    just pull the plug off underneath, saves any faffing around getting the lighter out
    Sheffield
    I wasent able to get under the lighter theres not much access after i take out the ash tray.
    I cant seam to remove the the pice the ashtray pushes into I can see the Diag Port undereth a feel the bottom of the lighter but not enougth space to wire to it
    Feb 2006
    Dorset
    Pull the surround up around the gearstick , then removethe inner ashtry part , then pull the part with the ashtray lid on stright up , its just clipped in , also the junk tray below the heater controls pops out and so does the heater panel , there is loads of room behind to stick your box down.
    Sheffield
    I didnt want to pulll on thinks to hard SHould be ok now.
    Thanks to all of you for takeing the time to reply, Waht a Great Comunity You have Hear
    Regular Member Dezza's Avatar
    Glasgow
    Fitted my parrot ck3000 yesterday. put the control box behind the glove box and got my live feed from the cigarette lighter. If you unplug the connector from the lighter there is enough play to pull the wires out of the ashtray. Bit of a fiddle reconnecting but nothin too difficult.
  1. parrot ck3100 kit
    By andy.l in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2011, 09:24
  2. Parrot CK3100
    By graham22vti in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2010, 19:31
  3. parrot ck3100
    By bigmac in forum Parts for sale
    Last Post: 17th January 2009, 23:56
  4. Parrot CK3100
    By bigmac in forum Electrical & ICE (including SatNav)
    Last Post: 6th January 2009, 20:23
  5. Parrot CK3100
    By jonesy_ni in forum Electrical & ICE (including SatNav)
    Last Post: 2nd December 2007, 01:40
