Thread: Oil Change
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default Oil Change
    Sorry if its been posted before but i need to know for this weekend...
    1. What size is the torx sump plug and
    2. What size is the Hex on the oil filter housing?
    Thanks in advance
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    not sure on the sump plug but the filter housing is 32mm i think
    Cirencester
    T45 for the sump
    East Midlands
    Quote Originally Posted by Mugualigwian View Post
    Thanks in advance
    The oil filter hex on mine was this one....http://cgi.ebay.co.uk/OIL-FILTER-SOC...QQcmdZViewItem
    Jul 2006
    Northampton
    Trim : Sri
    Quote Originally Posted by jonr View Post
    T45 for the sump
    Quote Originally Posted by macdad View Post
    Thank you both. That socket looks about right, biggest i had was a 32mm and that was a bit too small! Whats the best way of getting the sum plug out ive heard its a bit of an @rse
    take the undertray off...it's on some twist panel fixings... then there's loads of room...remember jack and stands..
    Jul 2006
    Northampton
    Trim : Sri
    I know that bit lol! I meant best way to take the plug off and get the stuff out.
    [Ex]Admin Duncan's Avatar
    Sump plug shouldn't be an issue. Just crack it loose with a ratchet handle and then undo it by hand when you can. I use one of these....
    ....to catch and store the oil until next time I go to the local waste disposal site.
    If your sump plug points backwards then obviously you have to position the oil pan relative to where the oil is going to arc out to. Also best to warm the engine up a bit first so that the oil flows out quicker/smoother and you get as much of it out as you can.
    HTH
    East Midlands
    A piece of advice which stood me in good stead for 20 odd years,before you do anything else don,t forget to REPLACE THE SUMP PLUG LOL as its been known by some,me included to forget to screw it back,result a big pool of oil on the garage floor and 20 quid down the drain.
    Oops! lol
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. Manifold change poll: Actuator change or not
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 18:52
  3. Oil Change
    Last Post: 22nd March 2012, 10:45
  4. Change Discs - Change pads?!?!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2010, 09:54
vectra c using hex sump plug www.vectra-c.com
