Results 1 to 10 of 11
Thread: oil light then spanner light
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    Default oil light then spanner light
    2004 1.9 cdti,
    on way into work the oil light popped up so i stuck just under half a ltr in and the light was off
    then just as i get to work after 8 more miles the spanner and car light popped up
    question is is there a reason why this may have happened or am i better off popping into a garage to get it ecu read?
    or is it worth taking the battery off for 15 mins and seeing what happens LOL
    Baz
    Full Member Big Sig's Avatar
    Spanner and car light is a fault. Maybe worth getting it read but its up to you. If you start the car again and it does not stay on then fingers crossed it will be ok
    Mar 2007
    swindon
    seems to turn on and off so going to let it cool down a bit top the oil to correct level
    then re set the ecu and see what happens from there
    Baz
    Mar 2007
    swindon
    right
    after turning off it would stay off for 5/10 mins then come on again so took it to be read and low and behold its showing no fault even tho the car and spanner is on screen so they have cleared it and told me if it apperars again to pop back
    anyone else had this happen?
    car drives fine as it alwats has so im lost
    Baz
    If they cleared it then it must be showing a fault....
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    who cleared it? was it done by a Vx garage with Tech2? if not a Tech2 then their reader may not have been able to read the trouble code.
    Mar 2007
    swindon
    was a local garage
    he did say that there was no fault code on the reader so as per plasma the reader was no good that was being used
    as on way home it popped up again
    so i will be wise to take to vx as its booked for tomorow at a nice price of £70.50 just to tell me the fault
    baz
    Mar 2007
    swindon
    update
    just got back from vx
    error code is p2251, 02 sensor circuit low voltage bank 1 sensor 1
    2 questions
    how much for part number 93179226 vx wanted around £135 + vat can anyone get it cheaper
    and how easy is it to fit and where is the sensor i belive its near on the cat?
    Baz
    try and blag 'trade club' on it..that will only bring it down to £102 +V thou...
    when you go to fit the new one, use a proper lambda sensor socket...saves rounding it off as it will be in tight..
    remove the cars undertray and follow the exhaust back.. you'll soon see it..
    Mar 2007
    swindon
    think im going to sit on it a while as the lights not come on at all today or is this what happens with the lambda sensor when faulty
    baz
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
1.9cdti oil spanner light
