Thread: Wheel Bearing Noise Or Not? Help!!!
    norfolk
    confused Wheel Bearing Noise Or Not? Help!!!
    Hi All, I Am New To This Forum, And Looking For Some Advice.
    I Have A 2002 Vectra C 1.8 Ls, When Driving Along, I Am Getting A Loud Wheel Bearing Kind Of Noise,[sounds Like N/s/f], I Have Had This Checked By A Local Garage, And They Say That The Wheel Bearings Are Fine. I Did Have The Car Up The Other Day To Check For Play In The Front Wheels, And Yes There Is Play In Both. The N/s/f Tyre Also Was Quite Worn, So I Swapped The Front Tyres With The Rears To See If This Would Stop The Noise But In Didn't.
    Also The Garage Did Say That There Was Play In The Rack Inner Joints? Could This Be The Cause Of The Wheel Bearing Kind Of Noise Or Not? This Noise Is Driving Me Mad, Any Help Or Tips Would Be Great, Cheers
    Regular Member Durk's Avatar
    Aug 2007
    N. Ireland
    Mine has started this but its the Boots in the drive that is busted. You rear it only when you go over bumps it gets louder.
    norfolk
    Sorry What Do You Mean By Boots In The Drive?
    kent
    hi this is nothing to do with the steering rack ,what so ever,,could be down to your tyres,i had the same trouble,change 3 bearings and still there ,i was told it was the tyres,and not bearing,check for uneven wear on the in sides
    Maida Vale
    Don't mean to be rude, but what's with the Capital Letter At The Start Of Every Word? Only the first word of the sentence and names (of people or places) should start with a capital letter.
  1. Had enough of bearing the noise!
    By chrisschild in forum Suspension, Wheels & Brakes
    Last Post: 16th January 2012, 10:11
  2. Vibration Noise - Wheel Bearing?
    By si_hoss in forum Suspension, Wheels & Brakes
    Last Post: 9th September 2011, 12:36
  3. Replies: 0
    Last Post: 17th January 2011, 23:43
  4. Wheel Bearing Noise ?
    By STEVE S in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2008, 20:09
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
