Results 1 to 2 of 2
Thread: Oil pressure sensor switch
    Regular Member crucial's Avatar
    Oct 2007
    kent
    Default Oil pressure sensor switch
    It appears i have an oil leak from the oil pressure sensor switch underneath the car, or so vauxhall informed me. Can anyone tell me if i replace it , does it need to go back to be tech 2'd or anything, or is it pretty much "plug and play". Is it an easy job, or do i need any specific special tools to replace the switch?
    Jan 2006
    Skynet HQ EMEC#5
    Quote Originally Posted by crucial View Post
    I had the same problem on my 1.8 towards the end of last year. I changed it myself & didn't need tech 2.
    Mine is positioned on driver's side at lower rear of engine, above subframe.
    All I did was remove wheel, then use spanner or deep socket to remove / refit.
    HTH
  1. Replies: 26
    Last Post: 14th March 2014, 01:03
  2. z20net oil pressure switch
    By beat275 in forum Engine & Drivetrain
    Last Post: 28th February 2012, 13:05
  3. Oil Pressure Solenoid Switch
    By masj78 in forum Engine & Drivetrain
    Last Post: 1st January 2011, 13:19
  4. Where is the Oil pressure switch?
    By grandadwoody in forum Engine & Drivetrain
    Last Post: 30th September 2007, 16:17
https:www.vectra-c.comforumshowthread.php43647-Oil-pressure-sensor-switch
where is oil pressure switch vectra c
vectra oil pressure switch
where is the oil pressure sensor located on vectra
where is the oil pressure switch located vectra
vauxhall vectra c 1.8 oil pressure switch
oil pressure switch location 2006 vectra
2012 vauxhall zafira 1.8 oil pressure switch
