Thread: Cruise Control not working
    Regular Member Bucko's Avatar
    Pudsey
    Default Cruise Control not working
    Hi guys
    Driving down the M62 earlier today and coudn't get the cruise control to come on.
    Anyone got any ideas what i should be checking? Blown fuse, duff relay? or is it a trip to dealers?
    Regular Member Signum_CDTI's Avatar
    May 2007
    Somewhere and Nowhere....
    Try lifting the clutch pedal up with your foot - the springs arent too strong and sometimes need some help. If this is the case then it will stop the cruise activating....
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    mine has also stopped working, so i had it tech 2ed and come up with a switch not shore if it the clutch or the brake one
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    It won't work unless you have pressed the brake pedal - usually you will do this sometime before needing cruise but if you set off from a stop on the motorway and try to engage it without having used the brakes it won't work. The manual says 'For safety reasons, cruise control cannot be activated until the foot brake has been activated.' Is it that?
    Pudsey
    Ok, just to make things even stranger!!
    Driving to work this morning, pressed the button while doing 30 just to check and the ****** thing came on!!!
    Now I'm really worried.
    Regular Member Cleeker's Avatar
    Oct 2007
    N Ireland
    Same happened to mine just after I got it. Would only work intermittently. Left it in and they had to order a switch so they held onto it for a day. Dunno what the switch was and as it was under warranty I didn't ask any questions. Sorted ever since though.
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by vxvirgin View Post
    If you'd left a services and hadn't braked at any point, the CC won't operate.
    If not that, then as also mentioned the clutch spring is a favourite culprit, tested by hooking your foot under the pedal and pulling up a bit to see if it'll let you engage CC.
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    was just gonna say about the break pedal.. especially if you havejust come out the services and got straight back on...
    a replacement stalk if none of the above work are only a tenner at lmf...
    Pudsey
    OK chaps. On the way to picking up missus tried pulling up the brake pedal and clutch pedal, but both are right at the top of their travel so am assuming someone has already done the return springs on them. Tried using the brakes and then the CC but again no joy. But then on the way back it all worked fine??
    Looks like a trip to see my friendly local vauxhall mechanic so hopefully it is only a dodgy switch (fingers crossed).
    Ta for the suggestions
  1. cruise control not working
    By bigsteve3.0v6 in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2011, 21:53
  2. Cruise Control not working :(
    By Princess D in forum Vectra C / Signum Troubleshooting
    Last Post: 14th January 2011, 16:16
  3. Cruise Control - working again!!?
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2009, 19:30
  4. Cruise Control not working
    By jonnyc in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2007, 04:53
  5. Cruise control not working
    By armoured farmer in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2006, 21:07
opel vectra c manual cruise control not working
vectra cdti cruise control not working
