Results 1 to 3 of 3
Thread: Signum auto gearbox
    Regular Member Signum Dek's Avatar
    South Yorkshire
    confused Signum auto gearbox
    I've been reading through the threads relating to the problems associated to the auto gearbox, and failure of the coolant system, how much of a common problem is this, is it possible to find out if any warrenty/recall work has been done to the car, to cure the problem, the car is a 2003 Signum 2.2 direct petrol.
    Also where do I find the oil filter on the 2.2 engine, had a quick look round, but couldn't see anything, and is it possible to check the auto gearbox oil level without tech 2.
    Thanks Dek
    Regular Member benny's Avatar
    Feb 2006
    dudley
    check out www.z22se.co.uk for the oil filter info mate .....there is a small dip stick on the front of the gearbox just bellow and to the right of the engine oil filter you need the engine and gearbox very hot and the engine running when you check the level .....
    May 2006
    liverpool
    you need to remove the engine cover, the oil filter has a large round black plastic cover with a nut moulded on the top, i think it's at the r/h front of the engine.
    if your gearbox is an af35, it has a small green dipstick at the top front of the gearbox, it might be difficult to see from the top of the engine bay, you need to look between the battery tray and engine, through the hoses and wires. it is held in place by a 10 or 11mm bolt.
    hope this helps.
  1. signum 2.8 auto gearbox
    By viper8 in forum Engine & Drivetrain
    Last Post: 3rd June 2012, 21:05
  2. signum 2.8turbo auto gearbox
    Last Post: 29th December 2011, 18:54
  3. Signum Auto gearbox issues
    By fastcarmanaic in forum Engine & Drivetrain
    Last Post: 22nd July 2011, 11:02
  4. Signum Auto Gearbox - Advice
    By alhambra in forum Engine & Drivetrain
    Last Post: 22nd May 2011, 12:46
  5. change gearbox oil on auto signum
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2010, 15:41
