Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: Brake Warning Light
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default Brake Warning Light
    Without any warning or noise the 'warning' light came on on my dash/warning system.Hmmmm thought i, only got 40k on the clock so i trawled through the forum and checked the front brakes.
    Theres still approx 8-10mm of pad left on boyh sides and look almost 'new'.
    So im at a loss??..Does the rear system have a 'warning light',although visually these look ok to..
    Regular Member Steel's Avatar
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 202,800
    Have you checked the brake fluid level?
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    could also be a broken wire or the sensor has just touch the disc
    11 Post(s)
    Quote Originally Posted by nikroc View Post
    But was it the warning light for low brake pads?
    If it was, then a warning should come up in the LED display in the rev counter - a circle with 3 dashes either side of it.
    If however it was an exclamation mark with a circle around it, but not in the LED display of the rev counter, then others have already said, low brake fluid (or a faulty handbrake switch)
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Thanks for the quick responses.
    I've checked the fluid level,fine.
    The dash light is def the brake warning light and as for the wiring i guess the only way to check is a visual inspection(although a quick visual this aftie didnt show up anything) or a change of the wiring itself...
    Does the rear have the same 'warning'system?
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 202,800
    There is one warning indicator wire on the front nearside brake, the rears dont have an indicator. They are a bit fragile and normally break when you change the pads so its best to get a new indicator wire when you change the pads.
    11 Post(s)
    Quote Originally Posted by Steel View Post
    There is one warning indicator wire on the front nearside brake.
    Some of the earlier Vectra's had one each side.
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 202,800
    I stand corrected
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Mines on a 53 plate..does that count as an 'earlier' vectra?
    Dec 2005
    In the sponge-monkey tent
    A new sensor wire is under a tenner at a dealers and a doddle to fit, so might be worth trying that first.
    P.s mine was a 52 plate and only had the near side one.
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. 3rd brake light warning
    By madvenny83 in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2010, 07:26
  3. Brake warning light
    By dandsi in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2010, 16:32
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. Brake warning light
    By scar_vectra in forum Suspension, Wheels & Brakes
    Last Post: 23rd June 2007, 12:48
