Results 1 to 10 of 16
Thread: heater blower
    Ayrshire
    Default heater blower
    Hi Guys
    proud new owner of a 2004 Vectra, had it about 4 months and very pleased so far. However the heater fan stopped working, only works on the 4 setting. From previous threads I guess this is the resistor at the motor. (floor is soaking and I removed a forest load of leaves from in front of the pollen filter). My question is to get at the resistor I believe I have to remove the glovebox, how do I go about that? and is there any danger of setting the airbag off? Any help much appreciated.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    to remove the glovebox you will need to undo 5 screws open the door and you will see 3 along the top and 2 in each bottom corners and it will come out and it won't effect the airbags
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Default Heater fan
    Quote Originally Posted by Pete Kincaid View Post
    Hi Guys
    It could be the resitor, i have just read a post from Tommoturbo
    and he has one for sale, £22 plus p+p, pm him for some info !
    Ayrshire
    Thanks Gents, already ordered a resistor pack from local vx dealer £22 + vat
    Fitted it tonight and blower working fine
    Thanks again
    Sunny Dartmoor
    Top job that man.....
    Hi. Do you know what the part number is for the resistor?
    I have a 2002 52 2.0Dti Elite with dual zone climate. It has 7 fan speeds and none of them work. Is the resistor the same one as for lesser models?
    Also, I'm ok with removing the glove box, but where is the resistor located?
    many thanks.
    James
    Feb 2007
    Tamworth
    Default Resistor pack part number
    Quote Originally Posted by jwsturner View Post
    many thanks.
    James
    Hi m8,
    i think this may be the part number you are looking for: 9180020,
    but best to check with VX, to be sure it is right for your model and year ! !
    Jan 2008
    York
    Angry Heater Fan damaged.
    Hi, I replaced the resistor after water got into the car. Only problem is that the fan seems to have been damaged by water (chirps like a budgie) and has blown two resistors. Obviously needs new fan which is very hard to access.
    Default Good News
    After booking my car into my local VX dealer, I decided to investigate the problem before actually taking the car in. I checked all the fuses and then removed the pollen filter to access the motor to check it freely spun. It didn't (probably debris from the filter), so after a little brute force to move it, it the spun ok. Ignition on and fan works ok. So very happy that it's fine.
    I just wonder what the VX dealer would have done? They were talking new motor £225+fitting, regulator £130+fitting ..... or would they have done what I did???
    Always worth having ago yourself I think.
    James
    as per your other identical post....
    they would have replaced the parts.. VX aren't in the habit of trying to fix old units..
  1. heater blower not doing its job
    By coylo5 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 14:58
  2. Heater / Blower Fan
    By chris2464 in forum Bodywork & Interior
    Last Post: 5th January 2012, 13:30
  3. heater blower
    By bootneck85 in forum Electrical & ICE (including SatNav)
    Last Post: 18th April 2011, 00:40
  4. Heater blower!!!!!
    By mitch in forum Electrical & ICE (including SatNav)
    Last Post: 19th November 2010, 00:15
  5. Heater Blower
    By Woolly in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2008, 18:12
