Thread: De-badge
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    Default De-badge
    Does anyone know how to safely remove the vx griffin from the tailgate without disturbing the paint?
    Thanks Keith
    Cirencester
    pull it
    Regular Member Leviathan's Avatar
    Middlesbrough, Cleveland
    Very popular modification, plenty of posts on it and some differing ideas. A successful methid is to heat the griffin with a hair dryer to warm the adhesive and then use a credit card (or similar) to gently pry the badge off and then clean the rest of the adhesive off with a polish and elbow grease.
    Hot water is another method. Other tips for removing the adhesive is bug and tar remover and have also seen label remover suggested.
    I used the first method with top success.
    Regular Member Durk's Avatar
    Aug 2007
    N. Ireland
    Take your time. I used lots of warm water and got the badge at each side and pulled it off. Bit of tar and glue remover and a few coats of polish. Jobs a good'un
    Sunny Dartmoor
    I just pulled mine off with the help of matalan card, and got residue of glue off with finger and polish,very easy mod and makes the back end look alot better,easier to clean too.........
    Jan 2008
    Dundee
    thaks for all the great info folks, will have a go today
    Dont forget the before and after pics!
    Jan 2008
    Dundee
    Quote Originally Posted by Leviathan View Post
    I've just fitted an irmmy grille, DTM spoiler should be fitted on wed plus will be replacing vectra tailgate badge with irmmy one, as soon as thats done i'll get some pics up for you guys
  1. Replies: 8
    Last Post: 8th May 2012, 19:18
  2. which badge to replace vectra badge???
    By Jow20 in forum Styling
    Last Post: 24th May 2011, 10:41
  3. where to put my new opc badge
    By sri_joe in forum Styling
    Last Post: 7th May 2009, 22:05
