Results 1 to 10 of 25
Thread: De-badge
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    Default De-badge
    Does anyone know how to safely remove the vx griffin from the tailgate without disturbing the paint
    Thanks Keith
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    I used a hairdrier and a body filler spreader which got rid of the bulk and then carried on with my finger nail while still heating the area up.
    Finaly used some panel wipe to remove the excess glue and finished off with some Megs Scratch Ex and Megs Next Gen wax.
    Did the same on thr rear chrome boot strip as well. Others will have there own ways but for me it worked a treat.
    I think the two most popular methods are fishing line or point's cards with a bit of hot water for good measure !!!
    May 2007
    WINSFORD
    I didn't try the hotwater as the hairdrier took long enough so would of thought it would be gallons of hotwater and I never thought of points cards but as I had a few new plastic body filler spreaders I used them and the edges are quite fine to get in underneath.
    My neighbour said try using dental floss as he had used that himself on a car which I suppose is the same as fishing line.
    Regular Member DarrenLee's Avatar
    Shipley, West Yorkshire
    Did it yesterday...
    1 Kettle full of hot water and an old credit card/points card.
    Pour slowly half the kettle over the badge and then using the credit card push it gently through the bonding gel which will give way easily.
    After a few minutes of pushing the card through the bonding gel it should just peel off.
    Use the rest of the water to help remove the remaining gel stuck to the boot rubbing your finger over it gently.
    Job Done - (maybe a quick polish over the top to protect)
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    used dental floss.... but a strong thread will suffice. Use it like a cheese cutter wire.
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    i uesd a portable steam cleaner came of in seconds
    Jan 2008
    Dundee
    lots of great ideas there, thanks
    Regular Member Gregg's Avatar
    Aug 2007
    Great Wyrley
    Heat gun here, really quick job then a quick polish up once paint has cooled down
    Regular Member Burton's Avatar
    County Durham
    sounds fairly easy, i know what i am doing bank holiday weekend
  1. Replies: 8
    Last Post: 8th May 2012, 19:18
  2. which badge to replace vectra badge???
    By Jow20 in forum Styling
    Last Post: 24th May 2011, 10:41
  3. where to put my new opc badge
    By sri_joe in forum Styling
    Last Post: 7th May 2009, 22:05
