Results 1 to 10 of 11
Thread: where is the idle air control valve on the 1.8 16v?
    Regular Member glencol's Avatar
    derby
    Default where is the idle air control valve on the 1.8 16v?
    as above ,ive looked and cant see it. these newer type engines are a mystery to me. some pics would be nice if poss. oh its not the vvt one.
    derby
    anyone? i know its not a 1.9cdti but i still wouldnt mind some advice.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    there isnt one mate .....whats your problem .?
    derby
    trys to stall when pulling away.
    Feb 2006
    dudley
    the throtle body could be ****ty .....if ya take of the intake pipe and have a look inside and see if the flap is crudded up .....
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    give it more throttle mate.... it is a big heavy car
    and try a fuel adative to clean the injector's
    Midlands Mod Shop - NFFC.
    derby
    can you clean the throttle body while its still on the car?
    Feb 2006
    dudley
    what he said lol ......
    Feb 2006
    dudley
    yeah you can give it a little clean if it is megga cruded you may have to take it off
    derby
    i do give it throttle but the revs just drop
  1. idle control valve 1.9cdti 16v
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 1st October 2012, 10:03
  2. **Urgent help required - Idle Control Valve gasket**
    By Bloicy in forum Engine & Drivetrain
    Last Post: 23rd April 2012, 18:13
  3. 2.0 Turbo idle control valve
    By pipamish in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2011, 14:13
  4. 2.2 Non Direct Idle Control Valve
    By BaileySRI in forum Engine & Drivetrain
    Last Post: 19th February 2010, 17:22
  5. Help! 3.2 Idle Control Valve Gasket Needed (Leeds)
    By Hedgehog70 in forum Engine & Drivetrain
    Last Post: 25th May 2009, 12:39
vectra c 1.8 idle control valve
vauxhall vectra idle control valve location
vauxhall zafira idle control valve location
vectra c 1.8 engine air breather modification
https:www.vectra-c.comforumshowthread.php43552-where-is-the-idle-air-control-valve-on-the-1-8-16v
idle air control valve vectra c 1.8 petrol
vauxhall zafira A 1.8 idle control valve
vectra c idle control valve
insignia idle control valve
location of idle control valve on vectra c
where is the idle control valve on zafira 2003 1.8
how do i find idler valve on vectra c 2008 model
vauxhall vectra c sorting idle control valve
vectra 1.8 idle control
2003 vauxhall zafira 1.8 iacv location
06 Vauxhall Vectra 1.8 idle control valve
zafira air idle control location
idling control valve for zafira 1.8
idle air.control valve 1.8 vectra
where is the air idle control valve located on a Vauxhall zafira
idle control valve vectra 1.8 2000
idle control valve on vauxhall vectra 1.8 sxi petrol
where is the idle control valve on a vectra c
vectra c vvti idle control valve
