Thread: Reason for twin exhausts
    Melbourne, Australia
    Question Reason for twin exhausts
    (Not really a tuning question but it seems the closest category...)
    Hi everyone,
    On the Holden Vectra CDXi/Opel Vectra GTS/Vauhall Vectra SRi, there are twin exhaust pipes out the back. Are these just for looks or do they improve the engine performance? From what I can see, the same output figures are quoted for the single exhaust and twin-exhaust versions of the car.
    Thanks.
    As far as I was aware, it's purely a cosmetic thing.
    I agree with Duncan mate, unless you're going for a Stainless Performance system etc.
    Regular Member MLC's Avatar
    uk
    It halves the emissions......as long as they can only measure one pipe at a tme.
    Nov 2005
    Edinburgh
    Agree with the other comments, it's just for cosmetic reasons - the pipes are only split just before the back boxes anyway, so it's a pretend dual system. A 'proper' dual exhaust - i.e. with separate headers from each bank of cylinders and separate pipes running all the way to the back may make a slight difference to the horsepower, but unlikely to be significant. As far as I know, you don't actually need separate pipes for a 6 cylinder engine to maximise performance and with the 4 cylinder moters, there's even less point.
    Thanks everyone
    Regular Member POAH's Avatar
    Glasgow
    unless the system is a proper twin header twin pipe deal then having twin pipes at the rear is actually performance reducing because the split messes up the gass flow and would creat back presure.
    Regular Member Patrick's Avatar
    Jun 2006
    Singapore
    Quote Originally Posted by POAH
    hey, i was planning for a split twin pipe exhaust mod, but after reading yr post, it make sense, so i'll stick to one side then.
    Regular Member The Doc's Avatar
    'Norf Yorks.
    No performance decrease when I fitted my Irmscher twins. Infact felt pickup slightly quicker.
    But a poor designed system could decrease power.
    The Vectra's don't produce enough power to worry too much about back pressure. Only over 300bhp do you really need to start getting concerned massively about exhaust diameter size, backpressure etc. etc.
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    By effectivly doubling the volume of the pipe, the pressure would theoretically increase but the mass flow should be the same so you shouldn't see back pressure or a performance drop. Unless they bodged the join and created a bottle neck.
  1. Twin exhausts
    By Tango in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2009, 19:55
  2. Twin Exhausts
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 25th October 2007, 14:01
  3. Twin Exhausts
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 9th September 2006, 09:14
  4. Twin Exhausts
    Last Post: 26th March 2006, 11:51
