Results 1 to 10 of 16
Thread: water system problems
    Lanarkshire, Scotland
    Default water system problems
    Hi, I seem to have a problem with the cooling system on my 2.0 t petrol signum 2003 model, first i noticed that the temp gauge wasnt rising for around 5 or 6 miles after start up, then it seems to be ok staying at around 85 90. On having a look under the bonnet (not really my department) the water doesnt seem to be circulating as there is no movment at the header tank, the level is ok, on squeezing a couple of the pipes you get movment in the tank, apart from the large one coming down from the front right hand side of the engine as you look at it , not sure if this pipe should be full of coolant or not but it seems empty.
    Hope this makes sense, and has anyone have a clue . Seems to me like the water pump aint working or the coolant is air locked. If it is , is it any easy job .
    Thanx Marty.
    If there was a problem with the cooling system then it would overheat. That "empty" pipe could be a air pipe for the induction system.
    Hi, thanx for your reply , had another look and the pipe at the front does look like an air pipe. there def isnt any water going back through the header tank when the engine is running, i feel as though i am missing something obvious.
    Yours Marty.
    I have no idea if it does or does not on mine, tbh I have no reason to check.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    The car will not reach operating temp on that mileage especially on these cold mornings, therefore the thermostat stays shut and will not allow the water to circulate until the engine is warm enough. Try running it a little further then check it, remember if you are doing a lot of stop start driving it will take longer to heat up.
    3.2 v6 Signum and loving it
    Hi Thanx for your reply, we recently bought a Hyundai coupe for my wife and the engine and interior heats up so quickly being it a two seater maybe i have put two and two and made five, but i have a worry that the water /coolant isnt circulating as at the header tank there is no input, do you know if yours has or if there should be.
    Yours Marty.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    what you have got to remember is that all cars are different my Omega eatate took ages to heat up after 10 miles it was just starting to warm up with my Siggy it starts to warm up after 3 miles and is roasting after 10 but that is driving at motorway speeds almost from the moment I get to the end of our street. There are a lot of factors to take into account such as weather conditions and how fast you are driving, and if you have antifreeeze and what strength it is.If it does not heat up after 15 miles I would be slightly concerned and give the coolant system a flush. If you are not too far from me I could maybe take a look at it for you. though I am pretty sure there is nothing wrong.
    By the way the wife has an Agila and that heats up within minutes, small car big heater it is magic.
    Hi John, Just put two and two together and made four, see you at work on Monday and you can have a look at it , Seen east kilbride and the siggy and thought i know him, still convinced the water pump is gone hope you prove me wrong.
    Yours Marty.
    If the waterpump has gone then it will overheat!
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Quote Originally Posted by Marty View Post
    Yours Marty.
    Definately not the water pump. trust me I am a lorry driver when I have not got a broken wrist. Hehehehehe
  1. anyone else had problems with water in the boot of their signum?
    By dahmich in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2012, 23:37
  2. cooling system problems
    By vmb2722 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th July 2012, 19:59
  3. Could water in the passenger footwell be the cause of all my problems??
    By orangepeeleo in forum Vectra C / Signum Troubleshooting
    Last Post: 4th April 2010, 00:04
  4. Signum 2.2 Fuel System Problems (many)
    By knocker in forum Engine & Drivetrain
    Last Post: 8th May 2009, 08:01
  5. Aquamist 1S Water/Methanol Injection System
    By spoons in forum Diesel Engine related
    Last Post: 30th December 2007, 04:28
