Results 1 to 10 of 11
Thread: stereo upgrade
    Regular Member steve904's Avatar
    blackpool
    Default stereo upgrade
    hi i am looking for a bit of advise,at the moment i have a ncdc2013 unit its the 4 disc changer which jumps all the time so its got to go,would it be possible to change it for the cd70 navi.
    if so is it just a straight forward swap the old one out and the new one in.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Do u already have built in satnav? If not you will need the aerial (means replacing the roof aerial) The Dab aerial is about £100 so I think the GPS version is a lot more.Plus the cable between the aerial and the Head Unit then it should be ok. You will need to Tech 2 the old head unit out and Tech 2 the new one back in. Make sure the one u are buying has been tech 2 out of the donor car otherwise it will be an expensive door stop.
    blackpool
    hi thanks for that,yes it already has the sat nav,regards the new cd70 navi its brand new and never been in any vehicle, and its supplyed with a radio pass would that be ok,as i am not sure what tech2 is
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    No its not strait forward.. its different wireing harnes.. due to half can-bus (wich you have) and full can-bus the CD70 is using.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    a 2004 should be full canbus should it not?
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    If it has the ncdc head unit then it will be half CANBUS ant therefor won't accept the CD70. I don't think you
    will even be able to put one in with the correct wiring harness either .
    Regular Member Paulsvectra's Avatar
    Northumberland
    Your not having much luck Steve it's a good job you asked.
    Paul
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Think the best bet would be to put in a non OEM head unit then such as a JVC,Kenwood or Pioneer. Maybe double din size with all the satnav/bluetooth/lcd screen etc. U would loose you onboard computer tho, correct me if I am wrong here.
    blackpool
    thanks for all the info it seems you have saved me a lot of cash,the confusing thing is that i have the 54 plate signum with a ncdc2013(sat nav)and my mate has a 54 plate signum with the cd70 navi i am confused.com(lol)
    They changed to full canbus late 2004 so it must just be that your mate's was built later than yours.
  1. Vectra CDC Stereo Upgrade
    By jonagain in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2012, 15:09
  2. Stereo Upgrade
    By P3tchy in forum Electrical & ICE (including SatNav)
    Last Post: 13th December 2009, 12:49
  3. GID and Stereo upgrade question
    By redraptor_141 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2009, 22:46
  4. upgrade oem stereo
    By Keithy in forum Electrical & ICE (including SatNav)
    Last Post: 1st May 2008, 14:12
vauxhall vectra stereo upgrade www.vectra-c.com
