Thread: Not A Vec/Sig...But CDTi Noise...
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Vehicle : Vectra Hatchback
    Engine : 2.2 DTi
    Default Not A Vec/Sig...But CDTi Noise...
    This is on my 2007 (57) Vivaro Sportive 2.0 CDTi. Basicly, that really cold period we had not to long ago when Everything froze, triggerd a whining noise from the engine of said van.
    It changes with engine speed, and is getting progressivly worse over time. Took to VX dealer to (after arranging on Tuesday a 10:30 Appointment for today). I was there an hour, to which they found it "It has a Whining Noise". They now want me to take it back in so they can strip it down to find the fault.
    Any ideas as to what could be causing this? Its all warrenty work, but I still want to make sure the dealers dont fob me off.
    I don't know how these engines compare to the Vauxhall Range as I dont think the 2.0 CDTi is available in the cars?
    Thanks in Advance,
    Chris
    Not sure but isn't that the engine in the Antera too?
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    If it were the turbo, it would change with the engine but there would be a delay. If it is bang on, as the engine reves and falls it's not likely to be the turbo. If it isn't the turbo then it might be anything.
    Cirencester
    My money is on the Aux Belt pulleys/tensioners. Happend on my dads movana with similiar results
    Regular Member 30ltr nutter's Avatar
    dunstable
    i have heard that the vivaros suffer with fuel pump failiures may be its that causing the noise
    May 2006
    Wiltshire
    Engine : 2.2 DTi
    Turbo, no, thats working very well. Fuel pump, fitted in/next to fuel tank towards the rear? The noise is definatly coming from the engine bay, on the drivers side. Which, is where the belts are? I'm thinking along the lines of jonr
    Chris
    dunstable
    if iam correct i thought the fuel pump on all the cdti engines is attached to the front of the engine in some way and is run by the belt or chain
    Cirencester
    the wear out and start a whining / squeking, frictional type sound lol
    best i could describe it as
    May 2006
    Wiltshire
    Engine : 2.2 DTi
    Spoke to VX yesterday and they found the noise to be coming from the tensioner on the auxillary belt, so they fitting new one & belt etc.
    May 2006
    Wiltshire
    Engine : 2.2 DTi
    UPDATE:
    Hand my van over the Vauxhall, they took it apart, and recon its the Tensioner, as said above. However, the part is on back order from their suppliers? Is this right, how long should it take to sort out?
  1. Chirping noise on cdti
    By ChristopheCDTI in forum Engine & Drivetrain
    Last Post: 16th July 2011, 21:48
  2. V6 CDTi ticking noise
    By Celes in forum Engine & Drivetrain
    Last Post: 7th March 2011, 00:54
  3. CDTi 150 Whining noise
    By daveb1971 in forum Engine & Drivetrain
    Last Post: 21st October 2010, 21:22
  4. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
  5. sqeaky noise 1.9 cdti
    By zubs187 in forum Engine & Drivetrain
    Last Post: 15th June 2007, 14:39
