Results 1 to 10 of 24
Thread: 3.2 Head Gasket Gone/Going ??????
    Lincoln
    Default 3.2 Head Gasket Gone/Going ??????
    Hi Folks,
    I've just topped up the oil on my GSI 3.2 and noticed a lot of emulsified oil in the filler cap??? I have always had a little but now there is noticeably more. I haven't noticed any loss of power or miss-firing.
    The coolant level is fine and the dip-stick shows normal black oil.
    Does anyone know if a level of emulsification is normal on the GSI 3.2 or if I should be worried that the head gasket has gone or is going ?
    Any suggestions etc greatly accepted.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    have you clean the oil filler neck and the breather pips out as i hear they get blocked up. im shore some of the v6 boys will be along shortly to correct me
    Lincoln
    Thanks Glynn, I've cleaned the oil filler neck, and going to keep an eye on it as well as running temperature & dipstick - very frightened !!!!
    Regular Member j13hdb's Avatar
    Nottingham
    It's condensation on your filler cap pipe. If you take it off that will stop the sludge-it's caused by the cold air passing over that stupid long extension!
    Enter GSI 3.2 please........................
    Lincoln
    j13hdb, Are you sure mate, (I really hope so, crossing everything here! )
    I'll take the filler pipe off tomorrow.....
    Many thanks for your suggestion, just hoping it is OK .....!!!!
    Nottingham
    Mark who is GSI 3.2 will confirm! I've got the sludge in mine. If your oil and water are ok=happy days!
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Try thrashing the motor once in a while. Everything needs to get really hot, just as it was designed to do. Bomb proof motors, won't do any harm
    Nottingham
    Quote Originally Posted by gtr1000 View Post
    Mine lives on the red line but it's as said above!!!
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    take the filler neck off and refit cap prob solved
    Quote Originally Posted by yorkshireborn View Post
    Just what he said the main problem is the filler pipe gets cold air blown on it when you drive along so the vapour turns to sludge i had this on my 3.2 took the pipe off and all sorted now !!!!!!
  1. Head gasket ?
    By mrpoochie01 in forum Vectra C / Signum Troubleshooting
    Last Post: 5th May 2012, 15:55
  2. Head Gasket help please !!
    By mark_647 in forum Engine & Drivetrain
    Last Post: 4th April 2009, 11:57
  3. head gasket???
    By coylo5 in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2008, 23:04
  4. possible head gasket?
    By garvey in forum Engine & Drivetrain
    Last Post: 22nd March 2008, 12:44
  5. Head Gasket
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2007, 17:28
signum 3.2 head gasket
vectra c 3.2 head gasket
