Results 1 to 10 of 17
Thread: MAF sensor?
    Regular Member littlesxi's Avatar
    Oct 2007
    derby
    Default MAF sensor?
    has anyone had any problems with their maf sensor if so what was it and what were the symptons of its failure,im just trying to eliminate different things from my car which i am having problems with.
    Admin plasma's Avatar
    On the Forum
    315 Post(s)
    Engine : 150
    Mileage : 74000
    tell us a litte more about the problems you are having...
    If the MAF is totally shot then she'll drop into limp mode.. will normally happen when you try to boot it too hard..
    Oct 2007
    derby
    im having most of the problems when it gets up to running temp or hotter especially when ive sat in traffic for a few mins,it struggles on power when pulling off it smokes and it judders whilst driving along and pulling off.i spoke to someone at vauxhall about it and they said they are prone to the maf sensor,egr valve and inlet manifold failingand the only thing they could really do is replace all of them till they find the problem starting with the cheapest first and then going through them until the problem is solved.
    On the Forum
    315 Post(s)
    Engine : 150
    Mileage : 74000
    Pity no-one is near you.. the MAF is a doddle to change and could easily be swap tested by a willing victim to test it
    Mine had excessive smoke before i had the inlet manifold changed due to the swirl valve rod BUT they also cleaned up the EGR valve too so either one of them could have caused the smoke..
    MAF i would try to swap with someone to test drive.
    EGR is next which requires a bit of fiddling around..
    Inlet Manifold is an absolute SOAB ..
    Oct 2007
    derby
    cheers how much of a job is the egr and how much was the inlet manifold to be changed or was it under warranty?oh and how much is an egr valve? mine is a 2004 1.9 cdti 120
    On the Forum
    315 Post(s)
    Engine : 150
    Mileage : 74000
    not 100% sure on the 120bhp but on the 150bhp its 2 bolts and a couple of waterfeed pipes i believe at the rear right hand side of the engine. Inlet manifold u need to sit down for.
    all in all £744 inc a diagnostic test (which included 5hrs Vx labour)
    Regular Member vectravirg's Avatar
    Bolton
    Quote Originally Posted by plasma View Post
    Mines having a new MAF fitted Monday, has the exact same problem as Plasma describes.
    About the fifth part fitted to try and cure the problem.
    Oct 2007
    derby
    f***ing robbing ba**ards whats that £244 for the part and a £100 an hour for 5 hours,is there no discount for it being a common problem with something they have not manufactured properly.
    South Central England
    9 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Changing the inlet manifold requires removal of the common rail and associated pipes, which means draining then re-priming afterwards. Big job.
    Oct 2007
    derby
    wont be doing the inlet then,is the egr valve a diy job?
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
where is maf sensor on vectra 1.9 cdti 120
vauxhall cdti120 maf sensor
