Thread: Does LPG Conversion lower your VED?
    Regular Member Ian's Avatar
    York
    Default Does LPG Conversion lower your VED?
    As above really, if you take a petrol car and add an LPG conversion kit, does your VED go down like a dual fuel from the factory, or LPG not effect your VED at all?
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    I'm not sure on that one, do you know anything
    about diesel / lpg conversions ? have herd it is
    poss !
    York
    I was thinking more for a petrol car. My friend has a MG ZT 180 which is in the new top tax bracket, so he now has to fork out more than double in VED. Seen as hes just bought the car and intended to keep it for 3 years, an LPG conversion may actually work out with him doing 80 miles a day commute. Just wondered how that may work with VED.
    Feb 2007
    Tamworth
    I think you can still get a goverment grant for
    half the cost of the conversion ! i am going to
    look into this a bit more myself.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by Kcs View Post
    No grants anymore. Costs about £1700 for a 1.8 Vectra C
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    It depends on the conversion/converter.
    Some conversions are 'recognised' by the DVLA if the installer is LPGA approved.
    Once the conversion is finished the installer gives you a certificate that you send to DVLA and they then can then reband you vehicles taxation class.
    It is all still based on emissions though, so it does depend on your car and the conversion you have done.
    www.boostlpg.co.uk is quite a good site for FAQ's etc.
    York
    Ah just read up. thanks sonic. If you use an approved installer you get a certificate to send to DVLA. This then registers the car as "Alternative Fuel". This gives you a paltry £15 reduction on the current prices, and I cant see that why that would change under Dastardly Darlings Stealth review.
  1. I Need To Go Lower!
    By Lean6 in forum Handling & Braking
    Last Post: 25th June 2012, 07:54
  2. Can Someone Lower my car please?
    By HuddyHudson in forum Photoshop section
    Last Post: 4th December 2010, 21:16
  3. Can someone lower my car for me??
    By danBoy in forum Photoshop section
    Last Post: 30th November 2010, 02:14
  4. Looking to lower my Sri T
    By Mark2.2 in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2010, 18:04
  5. Replies: 21
    Last Post: 30th November 2009, 22:21
