Thread: Traction light
    Regular Member Monza30's Avatar
    Bungay
    Default Traction light
    Traction light is always on first thing in the morning on my V6 CDTI, it does not go off untill you turn off and start again and then it takes around 20 seconds. Does not then come on for the rest of the day. Any ideas guys, or is is just a standard thing?
    Look forward to hearing your thoughts.
    [Ex]Admin Duncan's Avatar
    You mean it's on all the time you're driving? i.e. on steady as opposed to flashing?
    Bungay
    Yeah, its on all the time.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Cim maybe. I know I have a intermittent Cim fault and occasional it does this.
    Tyneside
    If it's on that normally means the TC is switched off, do the wheels spin up without the car killing the power.
    Bungay
    Whats a Cim?
    Bungay
    Its an auto so bit hard to tell. Light comes on without moving off or touching the button.
    Quote Originally Posted by Monza30 View Post
    Being a V6 you've got the TC button I assume? Does it go off/on as you push the TC button?
    Whats a Cim?
    Column Integrated Module - module in the steering column that controls a number of things.
    Vehicle : SRi
    Mileage : 137000
    It is an ECU that has the steering angle sensors on it which is part of the TC system, it also controls all you dash clocks, do they ever die, as in all drop? About £400 dealer fix I'm afraid mate if it is the cim. Best get it to dealers and get it plugged in, but that's going to cost about £50 just to diagnose any faults.
    Bungay
    I think I can live with it for £400!!! Need to est if the button works in the morning. no issues with any dials though.
  1. PLEEEEASE HELP - traction control light/power steering light on!!!
    By holdenvectra in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2010, 23:39
  2. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  3. ABS and Traction Light On Together
    By sjanisz in forum Engine & Drivetrain
    Last Post: 3rd March 2010, 15:09
  4. Traction light
    By viki_3.2 in forum Suspension, Wheels & Brakes
    Last Post: 21st December 2009, 09:34
  5. Traction/ESP light on in the wet
    By Daave in forum Electrical & ICE (including SatNav)
    Last Post: 23rd July 2007, 16:05
