Thread: Automatic locking?
    Regular Member nellsey's Avatar
    Nov 2005
    berkshire
    Default Automatic locking?
    I have been reading on another website that the C has automatic locking,
    although it depends when it was built. Needs to be 04 onwards IIRC and then does not always work.
    Apparently it automatically locks all doors when reaching 5-10 mph and then unlocks when removing the key from the ignition.
    This has to be initiated by pressing and holding down the lock button inside the car and the lock on the key fob at the same time. You then here a beep or two to say it has worked.
    Is this true?
    *slopes off to try it*
    Here, there and every where!
    Yes m8, works on mine. '54 SRi
    Have a look at this previous thread Nellsey - should help.
    Works on mine... activates at 6mph (10kph).... I think I already said that in the previous thread!!
    Nov 2005
    berkshire
    It does works on mine too
    The Mrs always wanted this on a car so I will tell her it cost....................
    How much is a tuning box for a V6Cdti auto?
    Ashington, Northumberland
    Got this set up on mine as well, but it doesn't always unlock when I switch the ignition off. I think it depends on hopw quick you stop and switch off. I find that if I let the car idl;e for a couple of seconds then switch off, it unlocks itself, but if I stop quickly and switch off almost before I've got the handbrake on, it remains locked (I wonder if the car thinks that it has stalled in that case). Anyway, just an observation.
    Wiltshire
    Can the auto locking AND the one press unlock be activated at the same time?
    I believe so. Look at the link in my post above - it gives instructions for both.
    HTH
    Wiltshire
    Yes I tried it and they both work together. One thing, though; the auto lock feature is enabled after 2 beeps. 1 beep is off.
  1. Automatic locking.
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2011, 01:33
  2. Automatic Box
    By WeDesign in forum Engine & Drivetrain
    Last Post: 9th March 2009, 16:07
  3. Automatic Door Locking
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2007, 20:32
  4. Automatic locking
    By bertxuk in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2006, 21:37
  5. Automatic Locking
    By storey_3000 in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2006, 20:16
https:www.vectra-c.comforumshowthread.php4334-Automatic-locking
