Thread: Dual mass flywheel change?
    Regular Member Nev's Avatar
    Gosport - Hampshire
    confused Dual mass flywheel change?
    Howdy!
    Has anyone replaced a dual mass flywheel? Is it a nightmare to do?
    I've got a 55 plate 1.9 CDTi 150 Elite, with 99,000 miles on the clock(!)
    I'm wandering if mine could be on its way out as when i start the car when she's been sat about for a couple of days, i get a very faint irregular 'plinking' noise from the gearstick / gearbox / flywheel area when sat in the drivers seat. When i press the clutch pedel in, it goes.
    Ideas?
    Cheers,
    Nev
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Quote Originally Posted by Nev View Post
    Howdy!
    Ideas?
    Cheers,
    Nev
    Definately sounds like the DMF. Mine does it more so when the outside temps are below 3 Deg & it has stood overnight..
    As for the changing of, I have not done one, But it should really be no different in procedure than changing a normal Solid flywheel.
    There are a couple of users on here that have done it ..
    Dean
    Regular Member madmark's Avatar
    great yarmouth
    just had mine done at a garage fitted dual mass flywheel and new clutch £875 told me parts was nearly £500 he said to me it was a nightmare to do done it in 1 day though hope this helps
    Regular Member Vid's Avatar
    May 2007
    In the inventing shed...
    My mate who is a Vauxhall mechanic has told me they are a big job to do! Unlucky mate!
    Gosport - Hampshire
    Ah cr*p!
    I guessed parts would be a bit pricy. I'm going to have a look at doing it myself though....looks like the best and easiest way is to get the car right up on axle stands and try to drop the 'box from underneath. I belive the whole front end is on some sort of sub-frame? I've not yet looked so not sure just guessing.. ...if I can get a Rover 220 'box out and on the bench in 20 mins, i'm damn sure this bu**er isn't going to beat me!
    If and when I get the balls to do it, i'll take phots etc and make up some sort of sticky, i guess it could a usefull bit of info in time as more fail.
    Anywho...that's the plan, will let you all know when I take the plunge!!
    Cheers,
    Nev.
    Regular Member skyrocketpilot2's Avatar
    daventry
    they are a right pain,ive done a few(more like ****** loads of them)as i work for vx.i wouldnt do one at home thats for sure..
    Gosport - Hampshire
    Quote Originally Posted by skyrocketpilot2 View Post
    Any chance of pointers / tips? (Apart from don't do it!)
    SOUTH SHIELDS
    Had my dmf/clutch replaced under warranty at 42k car has now done 93k and in the garage getting another one as we speak
    daventry
    pm me the details of your car and i'll send you some step by step instructions.
    Gosport - Hampshire
    Quote Originally Posted by ROB WOODHOUSE View Post
    No way! Is there a kit available to change it to stand style flywheel and clutch assembly? I'm sure there is one available for the Mondeo that use the same sort of thing.
    Not proving to be too reliable eh?!
    Nev
  1. DMF (Dual Mass Flywheel) How to change?
    By Snizzers in forum Engine & Drivetrain
    Last Post: 9th December 2011, 17:43
  2. Dual mass flywheel help
    By Garuk in forum Engine & Drivetrain
    Last Post: 14th October 2011, 14:30
  3. Dual Mass Flywheel
    By hairy31 in forum Engine & Drivetrain
    Last Post: 23rd December 2009, 20:36
  4. DMF - Dual Mass Flywheel
    By wittsy` in forum Engine & Drivetrain
    Last Post: 8th September 2008, 15:50
  5. Dual Mass Flywheel
    By Martyn21 in forum Engine & Drivetrain
    Last Post: 7th February 2007, 23:25
