Results 1 to 10 of 11
Thread: Rear brakes
    Regular Member copperdock's Avatar
    Nov 2007
    leicestershire
    Thumbs up Rear brakes
    My wife took the car out today and heard a noise coming from the rear of the car ,to cut a long story short one of the brake pads had worn down to the metal backing that was the one attached to the brake calliper piston and the one on the other side of the brake disc had about a 1/4 inch left.I rang vx they quoted £26-90 per set also asked about them changing the pads and was quoted £150 all in ,Robbing beggers .Went to halfrauds pads £25-49 piston rewind tool £19-99 adaptor i bought from elswear £7-50 had toget an adaptor thats for a renault modus no 4059 because the pins on the vx one were too far apart no4057 got the job done 25mins per side
    Administrator plasma's Avatar
    On the Forum
    410 Post(s)
    Engine : 150
    Mileage : 74000
    Nothing like the satisfaction from doing a job yourself
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    nice one mate as above great when you do it yourself
    Midlands Mod Shop - NFFC.
    Nov 2007
    leicestershire
    Yes as you say its great when you can do the jobs but its a bit rough on the old knees at my age i was pleased when i had finnished because i was done for.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by copperdock View Post
    Hope you sorted the sticking caliper mate or you could find yourself doing it all again sooner than later as they should be worn at the same rate.
    Nov 2007
    leicestershire
    Yes i know what you mean mate but it was the one that was attached to the piston that was worn down there was plenty of free movement on the piston so hopefully it wont happen again
    Nov 2007
    leicestershire
    I did check on the how 2 section to make sure it was no differant to other cars ive done
    Nov 2007
    leicestershire
    Thanks for coments guys ime off to bed early start in the morning
    Regular Member Leviathan's Avatar
    Middlesbrough, Cleveland
    Well done for giving it a shot!, tools will come in handy next time too so long term saving!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I made a rewind tool when I did mine, basically a big diameter bolt and welded 2 pins on, using a spanner on the flat of the bolt head worked a treat, whilst applying pressure with a 'G' clamp.
    Making one was quicker / easier and certainly cheaper than finding one in a factors and buying it. Also, didn't see the point in buying one as they lasted to about 67K and I don't think I will have this car long enough to have to change them again.
  1. need help for rear brakes
    By sharney2011 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th October 2011, 18:20
  2. rear brakes
    By johnytaff in forum Suspension, Wheels & Brakes
    Last Post: 4th March 2011, 19:33
  3. scraping noise from rear. rear brakes? upgrade?
    By Whippy in forum Suspension, Wheels & Brakes
    Last Post: 5th March 2008, 01:26
  4. Rear brakes
    By dan1983 in forum Suspension, Wheels & Brakes
    Last Post: 22nd May 2007, 21:09
