Thread: help
    Nov 2005
    newcastle upon tyne
    Default help
    can anyone help i have got a hell of a whining noise from front drivers side wheel sounds like something catching but nothig ther when i have looked so can anyone help
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    sounds like your brake pad sticking or a wheel bearing on the way out mate or a drive shaft on the way out
    Mileage : 000
    It might be a wheel bearing? have you bashed the kerb a bit hard in the snow.does the noise change when you slow down "etc",if it is a wheel bearing it should be there all the time rather than an intermitent noise.The front wheel bearings are useually prity hefty though.
    Nov 2005
    newcastle upon tyne
    the noise goes when i slow down when i move stearing wheel side 2 side there is a slight whining noise
    Regular Member woodster's Avatar
    What tyres is it sitting on just out of interest.
    Ashington, Northumberland
    You say it makes the noise when you move the wheel left to right and vica versa. If you have the engine running, with the car stationary and move the wheel side to side, does it then make a loud groaning noise whilst turning the wheel in either direction? If it does, check the power steering fluid level and if it is low, look for leaks before topping it back up.
    Regular Member Ian's Avatar
    York
    easy check for wheel bearing:
    jack up car and try and wobble the wheel left and right and up and down. Any play means the baering is shot
    easy check for driveshaft:
    turn the steering onto full lock and drive slowly with the window down. If there is a clunking noise then very possible the driveshaft is shot. (remember to do one drive going left, and another going right)
    power steering will whine when at standstill - its the motor pressurising the fluid.
    as Gary3306 said, easy to check power steering fluid.
    Quote Originally Posted by pte
    It's the motor TRYING to move the fluid, but because there's none there, or not enough, it is trying to move air or airated fluid. It is called CAVITATION and it is not desirable at all. It will eventually pit and score the elements within the pump. That's if it is the cause of the noise he's getting of course.
    Nov 2005
    newcastle upon tyne
    had it back to garage were i bought it & they said its a sensor so its getting done on warranty
    Regular Member cyb's Avatar
    Quote Originally Posted by stevietiger
    I get a similar noise from the passenger side funny thing is I only hear it when the wifes in the car with me
