Thread: Front knocking sound
    Regular Member LAV6Y's Avatar
    Oct 2006
    Lisburn, NI
    Default Front knocking sound
    Hey dudes,
    well i now have a new noise....At first i thought it was the suspension but i've came to the conclusion that it cant be.
    When i come to a complete stop and go to move off i hear a knocking sound. It only happens on the initial acceleration. I'm beginning to hear it more and more. I have thought it maybe could be the engine mounts but i'm thinking worst case, as usuall and i'm scared that its something to do with the drivetrain as i only really hear it when the car starts to pull.
    Please help
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Does sound like a mount to me.
    Have you taken a look at them?
    Nicking Ya Dinner.
    Simple check 1st, empty the glovebox and the boot of contents and check the bike wheel is secure.
    Look under the seats also for old rubbish like a bottle etc, I've had this in the cab before and it turned out to be a Smirnoff Ice bottle, empty a'nall
    Oct 2006
    Lisburn, NI
    I've done that VV, thanks anyway mate.
    I tried all this this when i thought i had suspension problems.
    Where are the engine mounts to check them please??
    Nicking Ya Dinner.
    The general one for this is the radiator mounts.
    Regular Member ChrisFox's Avatar
    Feb 2007
    Northampton
    I have two really annoying knocks on mine, one I have been told is worn anti roll bar rubbers which apparently are expensive to change???
    The other the garage can never find!!!
    Interesting to hear that it can be the radiator mounts, I will check that, although you cannot get your hands anywhere near it...unless you have REALLY small hands!
    UK
    The anti roll bar rubber mounts are not expensive, only a couple of quid each. I replaced my radiator mounts first, took it for a test drive and the crunching noise was still there (when going over speed bumps), I then changed the anti roll bar rubbers and that sorted the problems. I would replace the anti roll bar rubbers first as the radiator mounts are £11 each and you need two of them.
    Oct 2006
    Lisburn, NI
    Quote Originally Posted by cookie View Post
    Glad you got it sorted mate but Can you give me any clues how to change the rubbers mate??
    As said before but...the noise isn't specifically when going over speed bumps (or the like) it seems to be when moving off from stationary?
    I'll get a good listen on the way home again anyway.
    Pics would be brill.
    Regular Member Woodsta's Avatar
    May 2006
    Kent
    I had this problem!
    It was a loose bolt on the end of the wishbone arm!!
    it was the bolt on the circular rubber barrel end.Simply tightened it up.
    Hope that makes sence?
    Could also be suspension top mounts loose/ worn.
    Take it to an ATS or similar to check for the worn / loose mounts. It should be a free check.
    Woodsta
    Western Australia
    hey guysI have a similar knocking noise - have been told by my Holden dealer that it is normal and ABS related. Mine only happens when the car is cold or not driven for a few hours, and only when in drive, not reverse.
  1. knocking sound
    By leedslads in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2012, 14:20
  2. Knocking sound when braking
    By JezzerD in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2011, 20:44
  3. Knocking Sound From Drivers Front Wheel
    By corderz in forum Suspension, Wheels & Brakes
    Last Post: 11th March 2011, 03:10
  4. wonder what the knocking sound will be tomorrow..
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2010, 06:10
  5. Knocking Sound Found?!?
    By B00mer in forum Suspension, Wheels & Brakes
    Last Post: 6th April 2009, 14:06
