Thread: Saloon Interior
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    Default Saloon Interior
    Hi,
    Will the interior (front seats, rear seats, door cards) from a pre-facelift saloon fit in my pre-facelift hatchback?
    also are there any special steps to swappin the interior, e.g. tech 2 etc.
    thanks
    Carl
    Jan 2006
    Skynet HQ EMEC#5
    I have a saloon Carl, now as far as I'm aware;
    The rear door is a different shape to the hatch, so door card would could be wrong. If you compare the pics of my saloon & Payney's hatch you will see door shape.
    Saloon:
    Hatchback:
    The saloon rear seats are locked in position by metal loops on the parcel shelf panel.
    are the hatch ones locked in place at the side near c-pillar?
    If you want later, I'll try & get some pictures of the rear seats?
    if u could get some pics that would be great, thanks.
    i cant actually remember where the rear seats lock in the hatch. ill have to ave a look tonite.
    Jan 2006
    Skynet HQ EMEC#5
    Pictures as promised
    Hope these help
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Right been there done this. All the door cards are the same. The only difference is the back uprights. They will not change over as they fix to the bodywork in a different way.
    Taken from another post of mine the full story:
    So to clear it all up
    You can change the interior from a hatchback preface lift into a facelift and vice versa (the only difference being is the long strip that goes on the dash which is a different shape, the little strip on the drivers side fits). Been there done it
    Saloon must be changed with a Saloon as the rear seat uprights are different (but you can put a hatch version in if you put a bit of effort in ) Same rules apply as above when its a prefacelift or not. Been there done it.
    Estate must be changed with another estate as rear door cards are different although the same rules apply as above when its a prefacelift or not.
    Signum only with another Signum as the rear seating plan is different and the rear door cards. Same rules for Facelift and pre as above.
    You can change front seats between any model and front door panels. Been there done it. (assuming all the front doors are the same size lol)
  1. leather interior from a saloon
    By Vectra boy in forum Bodywork & Interior
    Last Post: 6th September 2012, 16:27
  2. Saloon interior into a hatchback?
    By LeeU in forum Bodywork & Interior
    Last Post: 1st December 2010, 16:06
  3. Saloon interior into a hatch question?
    By lee866 in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2009, 23:06
  4. Leather interior (saloon)
    By poves in forum Parts for sale
    Last Post: 1st January 2009, 22:55
