Thread: front anti roll bar rubbers
    london
    Default front anti roll bar rubbers
    I need to fit anti-roll bar rubbers on the front of my vectra, but does anyone know which way the cut outs face. the last set where fitted at the dealers the left one faces forward and the right one is to the rear.
    I am pretty certain the cut outs should face to the front but can anyone confirm this.
    fitting them looks pretty easy, but don't want do them twice.
    Jan 2006
    Skynet HQ EMEC#5
    I think mine need to be changed soon, how much are the rubbers, & what are they like to fit?
    Portadown, N.I.
    I really dont think there's a right or wrong way, but when I did mine I put them both with the split facing front. But I'm pretty sure that they look the same either way.
    Fitting them is made easier if you use a small ratchet torx spanner as access is limited unless you drop the subframe. Dont undo the rear torx bolts fully, take the front ones out and then the metal bracket can slip off. Re-assembly can be a bit tricky, but just squeeze the new bush on the bar, hook the metal bracket back on the rear bolt. Some try and prise the front of the bracket down with a crowbar or use vicegrips to clamp it down to insert the front torx, then tighten both torx.
    Then do the other side.
    Tim
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Insignia elite tourer vxline biturbo
    Trim : Elite vxline
    Engine : 2.0 biturbo
    Mileage : 80000
    a bit of washing upliquid haelps to fit the bracket back on
    Regular Member Mick B's Avatar
    North East
    And I bought some new front bolts a few mm longer and saved the hassle of straining myself trying to clamp the bracket down with the fatter new bushes
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Quote Originally Posted by Ian T View Post
    £5.12
    Regular Member Zark's Avatar
    Herts
    the dealers have diagnosed my rumbling creaking suspension as 'front roll bar bushes and modified radiator mounts required'
    they quoted £135 to supply and fit.... Does that sound over the top?!?!?!?!
    has anyone got the part numbers for an 04, 1.8 LS - and i'm guessing it's do-able for the enthusiastic amateur using only a jack?
  1. Front Anti Roll Bar Rubbers
    By ciscokid75 in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2013, 21:09
  2. Front Anti-Roll Bar New 25.2mm
    By paulhb in forum Parts for sale
    Last Post: 7th March 2010, 14:14
  3. *New* front anti roll bar 25.2mm
    By danBoy in forum Parts for sale
    Last Post: 10th February 2010, 22:44
  4. Front anti roll bar
    By Tom Tom in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2009, 18:38
  5. Play in front anti roll bar ? is that ok ?
    By simac in forum Suspension, Wheels & Brakes
    Last Post: 13th February 2008, 12:43
