Results 1 to 10 of 21
Thread: accessory socket / cigar lighter
    May 2007
    Dartford
    Angry accessory socket / cigar lighter
    Had the fridge running in the car at the weekend from the front ciggie lighter socket. (ive got a 04 LS estate so no socket in the back or in the boot)
    Anyway went to use the lighter and it wouldnt push in all the way. Pulled it out and there was a piece of metal in there that had fell out of the fridges 12v socket.
    Pulled the bit of metal out with some needlenose pliers and popped the lighter back in, and pressed in the button...
    Now it wont pop up again, its stuck in, I suspect its probably shorted out.
    Anyway is there a fuse for this and if so which one is it as I dont have the original hand book for the car? (i dont want to pull out all of them one by one to check) Or is there another problem here?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    sorry not the topic but you can check if you have the car ready for socket ind the back, did that on mine cost 80 dkk (8£ but your prices is half of denmark so about 4£, quick guide of made mine http://danborg.org/opel/stroemudtag.pdf (sorry its in danish but pictures and parts numbers are there)
    May 2007
    Dartford
    Hey thanks for that, been meaning to put one in the back for ages but wasn't quite sure how to
    Engine : 2.2 Direct
    if you dont understand the danish ill besuprised if you doo... (then just ask)
    But takes 5 minutes incl. finding stuff and putting them away
    cant find my manual right now so cant help with the fuse.
    May 2007
    Dartford
    No problem, it looks pretty simple from the pics
    Quote Originally Posted by tempo View Post
    Fuse 22 (30amp) in the passenger side dashboard fuse box.
    You can download a handbook for your car from Vauxhall's website once you've signed up for 'my vauxhall' (for free)
    May 2007
    Dartford
    Thanks Dave will try and fix it tonight when i get in from work. Will also sign up to the website
    Regular Member logi6260's Avatar
    Wakefield
    I've has a look in the back of my veccy 'facelift life estate' I have a small connector with brown and black wires, it is a T shape, from memory when fitting my car kit i think that this is the same connector as the front cigarette lighter, Does that mean that i can just buy the accessory socket and plug it in without having to add any wiring?
    Engine : 2.2 Direct
    Yes, that what i did (its my that made that small guide, in danish thou)
    Wakefield
    Quote Originally Posted by kenp View Post
    I thought it was but couldnt quite make out the first picture with the connector in it.
    My local VX dealer is shocking at finding the parts on the computer, it took about 30 minutes of looking before i gave up and told them that i would go home and look on here, then give them a ring with the Traction Control Part No so they could order it for me!!
  1. Cigarette lighter socket wont work with lighter
    By Aaron1990 in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2012, 18:21
  2. cigar lighter
    By J18BES in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2009, 21:02
  3. Cigar Lighter
    By Oakwood in forum Styling
    Last Post: 26th March 2009, 15:40
  4. Cigar Lighter / 12V socket
    By Dio in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2007, 02:26
