Thread: Final help with pinouts on back of CDC 40 Opera please......
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Final help with pinouts on back of CDC 40 Opera please......
    Right have made harness up for Dab (Dab L,Dab R and Dab GND) phone (Ph+ and Ph-) and sub (using sub+ and Sub-).
    So I am left with RSA L,RSA R,RSA GND,RSA SWC which I have not got a clue what they are for. So before I complete the harness can some one tell me what they are for incase it is something else I can add
    Also do I only need the 2 pinouts for the Sub which is an amplified one?
    Cheers for your help so far guys
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Its just a mono output for the subwoofer, hence the two pins.
    I don't know what the RSA pins are for.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default So what is twin audio???????????
    I have found the following on a German site:
    RSA L = signal connection to the Twin Audio, left channel
    RSA R = signal connection to the Twin Audio, right channel
    RSA GND = GND ground connection to Twin Audio
    RSA SWC = control line to Twin Audio
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    is it for the rear audio options on the back of the arm rest?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by lofty View Post
    Could be, I now can remember seeing something like that somewhere
  1. Signum ECU Wiring/Pinouts
    By kildrum in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 14:00
  2. Pinouts needed
    By jimmyfloyd in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2010, 18:49
  3. pinouts
    By oldcommando in forum Electrical & ICE (including SatNav)
    Last Post: 20th November 2009, 10:02
  4. Dab wiring and quadlock pinouts
    By ronnie63 in forum Electrical & ICE (including SatNav)
    Last Post: 27th July 2009, 15:32
  5. CD70 Pinouts
    By Ashtoroth in forum Electrical & ICE (including SatNav)
    Last Post: 2nd December 2007, 21:19
cdc40 opera rsa
cdc40 rsa ground
rsa gnd
cdc40 pinout
