Results 1 to 7 of 7
Thread: CDR2005 with kenwood DNX7200
    Mar 2008
    Norfolk
    Default CDR2005 with kenwood DNX7200
    Hi
    I was looking at getting something similiar to http://www.caraudiodirect.co.uk/kenw...th-p-5739.html - probably that one, but I may change my mind.
    Would this fit, replacing the current CDR2005 ?
    I am assuming I would only need adapter as stated http://www.caraudiodirect.co.uk/vaux...or-p-5838.html - I do have an Aug 02 Vectra so I think thats the correct one.
    I'm assuming buttons on the wheel would no longer work, as well as the screen with temperature & time, is there anything I have missed with this or does that cover it?
    Thanks.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Possibly the wiring harness adapter from the orginal plug to the back of the new unit. I am sure u will need one.
    May 2007
    Dartford
    you may also need one of these if your car has a seperate aerial (mine did and I had a CDR2005)
    http://www.caraudiodirect.co.uk/aeri...64f217bce156be
    Halfords do them for about £3
    You will also need a wiring harness.
    Also i think you can get an adaptor for kenwwods to make the steering control work.
    Have a look on here for what you need (4 digit radio)
    http://www.nexxia.co.uk/Car_Stereo_f...all/vectra.htm
    Mar 2008
    Norfolk
    Thumbs up
    Thanks for those.
    I think I will just get the separate aerial regardless, not going to break the bank if it isn't necessary.
    Regular Member kenp's Avatar
    Feb 2008
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    if you cange then you also have to swich red and yellow wire as they are swiched.
    then no wiring harness needed (only for steering control)
    May 2007
    Dartford
    Hey Kenp, is that true for all aftermarket stuff, as ive never got my DVD player to work and havent got round to sending it back yet.
    If its something silly like the wiring then that saves alot of hassle
    (I bought it from Hong Kong although it was advertised as in the UK )
    PS sorry for the hijack
    Feb 2008
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    ONLY if you have ISO plugs on the radio (ect. CDR2005 and other radios with ISO).
    On VX/Opel they swiched the "constant on" and "power on" cabels. so quite posible thats your problem. if it works with ignition, and after ignition off, it loses all setings that is probaly the problem.
  1. For Sale: Kenwood Kenwood DPX-503U Double Din CD / MP3 / USB player AND Fascia!
    By John LE in forum Parts for sale
    Last Post: 3rd December 2011, 13:49
  2. cdr2005 not for my car??
    By jamie_hepp in forum Electrical & ICE (including SatNav)
    Last Post: 28th October 2010, 21:41
  3. kenwood dnx7200 install questions
    By barracuda in forum Electrical & ICE (including SatNav)
    Last Post: 1st June 2008, 17:14
  4. Cdr2005
    By vectraturbo in forum Electrical & ICE (including SatNav)
    Last Post: 6th August 2007, 14:57
  5. Cdr2005
    By bluebirds1975 in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2007, 22:54
