Results 1 to 10 of 30
Thread: Electric mirror problem.....
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    Default Electric mirror problem.....
    A few weeks ago my drivers side mirror started to misbehave.
    When you adjust the drivers mirror it also adjusts the passenger mirror at the same time.
    The drivers mirror will also not come 'in'. If you try to move the mirror 'in' it just moves down towards the floor, so you have to open the window and use a bit of 'handraulic' power to push it in.
    The mirror motor has been replaced, and today the switch panel on the door has been replaced but it hasn't solved it.
    The dealers are now going to get in touch with vx technical to see if it's a software/wiring issue.
    Any ideas?
    Anyone else had this problem?
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by sonic View Post
    That's normal on a facelift. With the right hand mirror button on the driver's door pushed in, both mirrors will move at the same time i.e.up and down and in/out. If the left hand mirror button is pushed in then only the passenger mirror will move. The sequence, in terms of adjusting, is that you would push the driver's side mirror button down and adjust the driver's mirror to suit (ignoring what the passenger one is doing), then clcik over to the passenger side button and adjust that to suit. Then once done, click down the driver's side and if anyone else drives the car and has to adjust the mirrors, the theory is that by having the mirrors moving together it adjusts them quicker. I personally prefer the pre-face way - one mirror moving at a time.
    That's obviously not normal. I can't see how the switch panel would be the issue. I think that was an unnecessary charge. I would have thought maybe the motor, but it would appear not. Last thing I can think of is the PDM or DDM (Passenger/Driver Door Module) but they're a few squid so not something you'd want to replace just to see.
    I wonder if it's just the mechanism in the mirror housing getting a bit jammed/stuck up - could just need cleaning?
    Regular Member andy13's Avatar
    I've got a very similar problem whereas the driver side mirror is also moving the passenger side as well. But as i'm the only driver it doesn't really bother me. If anybody does have any ideas they would be appreciated.
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    mine does this too
    Full Member Big Sig's Avatar
    Quote Originally Posted by andy13 View Post
    Read Duncans post
    Mine is pre-facelift and there was never any problem with it until about 2 months ago when it just started moving both together. A bit bizarre to say the least. I was just gonna ask my local garage to have a quick look when it goes in 4 its mot
    Oh right, I didn't realise that. Seems odd that it does what the facelift ones do though.....
    Feb 2007
    The strange thing is it never moved the passenger mirror at the same until a few weeks ago!
    Cost wise I'm not too bothered as so far it has all been done under warranty.
    D, where or what is the module?
    Mine did it after I replaced the PDM when I fitted the electric folding mirrors, which I accepted as it was obviously how the module came programmed - wasn't sure if it could be changed to the other method or not. But for it to be doing it the pre-face way and then suddenly change is very odd.
    Sonic - the PDM and DDM are situated in the doors behind the door card. They control things like the windows and the mirrors. Hadn't realised it was under warranty - in that case go for it! lol Could be a faulty PDM or DDM.
    Feb 2007
    Cheers mate, I'll give them a ring tomorrow and see what vx Technical have come up with, and if no joy then I will suggest they look at changing the DDM/PDM.
  1. electric mirror
    By silky in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2012, 15:22
  2. Electric interior mirror
    By portreathbeach in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2012, 19:04
  3. electric mirror fault
    By TAL in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2010, 14:33
  4. Electric door mirror....
    By swirl80 in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2009, 15:26
  5. Electric mirror gremlins!!
    By Pecojess in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2009, 18:36
vectra electric mirror problem
