Thread: pippercams / fast road cams.
    Regular Member rickyroo's Avatar
    shropshire
    Default pippercams / fast road cams.
    Been looking into these for a while now but beleive will have to get the car mapped to run them. Am I correct or can I just fit and away I go?
    Looking at 270 deg inlet and exhaust.
    [Ex]Admin Duncan's Avatar
    I'm no expert on that, but I'd have thought as you're basically altering the timing of everything then you'll need to reflect that in the engine software, otherwise it'll run like a bag of bones or even cause damage?
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Also depending on the lift uprated valve springs and on some engines machining the head to take the springs.
    Regular Member Steel's Avatar
    Sheffield
    Trim : Sri
    Mileage : 198,500
    Never played with a Vectra engine so I don't know how the valve timing is set but the valve timing on any engine is critical. I once put too hairy a cam in a race engine, it was a carb engine and the cam was for the fuel injected version. Finally managed to get the valve timing set for it to run with a vernier cam wheel but the valve overlap was so hairy it used to spit fuel and flames out of the carbs on tickover.
    I think its unlikely anyone would sell something that hairy for road use but the wilder the cam you go for, the less tractibility in normal use would be the result. I would agree you will probably need a remap as the fuelling would need to be changed to cope with the increased valve opening times and to get the benefit of the increased overlap.
    Regular Member mushy2007's Avatar
    Liverpool
    I fitted a piper mild rally cam years ago in a carb'd car and just turned the dizzy cap with a flash gun to get the best timing.
    You need advice off GSI 3.2 for this mate, however as steel siad its worth while to change the valve springs and buckets etc to make it work well with the cam.
    shropshire
    cheers guys
  1. cams
    By HARRY SRI in forum Diesel Engine related
    Last Post: 17th April 2012, 15:55
  2. How fast will my GSI be at Thunder road?
    By paul667 in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2011, 11:41
  3. 3.2 v6 cams???
    By jackharrison12000 in forum Petrol Engine related
    Last Post: 25th May 2011, 17:15
  4. Cams...
    By Danwells72 in forum Diesel Engine related
    Last Post: 31st October 2010, 03:24
  5. Is there a Fast Road setup for the Vectra
    By Ziggy in forum Handling & Braking
    Last Post: 26th October 2010, 13:20
fast road cam panda 100hp
https:www.vectra-c.comforumshowthread.php43120-pippercams-fast-road-cams
