Results 1 to 10 of 13
Thread: 2004 Vectra 1.8 ECU light
    Wolverhampton
    Eek 2004 Vectra 1.8 ECU light
    Hi Folks,
    I have purchased a 2004 Vectra (LPG Converted) and having porblems with ECU light; had the Car Serviced and I was told that there is nothing wrong with the Engine.
    So just wanted help on how to reset it, so far I have learned that:
    1) Disconnecting the Battery for 30 minutes would do it
    2) Turning the Ignition off & on 20 times may also do it...
    So not sure?
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    hi m8 and to vectra-c
    the only way to reset the ecu is by tech 2
    Sunny Dartmoor
    Regular Member Paulsvectra's Avatar
    Northumberland
    to the forum
    Paul
    Regular Member moles-sri's Avatar
    Jan 2008
    south wales
    to vectra-c gang
    Regular Member welshy's Avatar
    Gwynedd, North Wales
    to the forum
    Full Member Jay Kay 313's Avatar
    Burgess Hill
    to the site & enjoy
    Astra Estate SRi XP 1.7 CDTi 100
    Regular Member Pecojess's Avatar
    Nov 2007
    Aberdeenshire
    Enjoy the site mate, lots of info here!!
    Regular Member Leviathan's Avatar
    Middlesbrough, Cleveland
    Welcome
    Admin plasma's Avatar
    On the Forum
    312 Post(s)
    Engine : 150
    Mileage : 74000
    Hi and welcome
    Yes if u disconnect the battery for a while it will clear logged fault codes and also 20 or so starts (as long as the fault isnt present or active) will clear it too.
    If after disconnecting the battey it comes back at some point the fault will need investigating by a garage with access to tech2 (fault code reader) equipment.
  1. Vectra 2004 ls dti spanner light help!!
    By jediknight in forum Vectra C / Signum Car Chat
    Last Post: 15th September 2009, 09:44
  2. Vectra 2004 ls dti spanner light
    Last Post: 14th September 2009, 19:20
  3. 2004 Vectra Exhaust Warning Light
    By fredthealienuk in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2009, 23:46
  4. Vectra 2.2 dti estate 2004 stalling/spanner light
    By XXXArlow in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2009, 09:19
  5. Vectra CDTI Spanner Light-2004
    By Vaux-Man-G in forum Vectra C / Signum Troubleshooting
    Last Post: 20th May 2008, 15:21
