Thread: Interior Trim Damaged - Can it be repaired ?
    Darlington
    Default Interior Trim Damaged - Can it be repaired ?
    Just noticed that I have (more likely the kids !!) damaged the rear door interior trim. Its the rippled plastic/vinyl piece to the top right of the silver chrome panel.
    Can this be repaired. My brother suggested holding a the cars cigarette lighter close to the damaged foam and it will reshape to the original look, with only a fine line where the trim is split. He works for Mercedes and has seen the repair done to dashboards, etc.
    Any thoughts on this ? Anyone know how much this panel would be to replace from Vauxhall or would it be cheaper to pass to a company such as Chipsaway. Again any idea how much this would cost.
    Thanks Mike
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    personaly i would try the hot repair, and if it doesn't work satisfactoraly then try e-bay and breaker's yard's
    Midlands Mod Shop - NFFC.
    member of the smoke patrol 230bhp+
    halford do a kit to fix that
    if you put a pic up of the hole door trim i know where there is a lot of parts for the vectra c
    Darlington
    Thanks for th eresponses. I'll try the heat fix, with a piece of glue to hold the tear. I'll pop into Halfords to see what they have to offer.
    The is the actual part damaged. You can just see it to the right of the text.
    i do thing they get them there
    let me know how it goes
    Darlington
    Thanks Chris. Does the top trim come as seperate to the bottom or is it a whole card for the side door?
    How much for the trim if all else goes wrong !
    Mike
  1. Interior Trim
    By Trembem in forum Bodywork & Interior
    Last Post: 4th October 2011, 18:31
  2. Interior trim Q?
    By Tavli in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2010, 13:08
  3. interior trim kit
    By Deztroyer in forum Styling
    Last Post: 9th April 2009, 16:01
  4. Interior Re-trim
    By parsco in forum Styling
    Last Post: 6th February 2009, 20:09
