Thread: changing bulbs on front
    newcastle
    Default changing bulbs on front
    hi just bought sum super bulbs off ebay how do i fit them on vectra c there for front lights just looked in engine bay and thought how the hell do i get them out
    Mileage : 000
    It is a bit of a tight squeeze but you can change the bulbs I have done this several times on mine, but I suppose it depends on what engine you have, But if you take the washer filler neck out it gives you more room to get your hand in, then remove the rubber cover and twist the plug on the back of the bulb. Or as some have done they have removed the bummper and then removed the whole head light.
    Mileage : 000
    Have a look at your other "bulb" thread.
    Larkhall
    tbh m8 you only need to ask once, someone will help you eventually!!!!!!
    Take the washer neck out and open the lid from the battery and you will have plenty of room to move around the passenger side. Driver side is a bit worse but if you have patience you will get it ok
    Regular Member craigmerry's Avatar
    Jan 2008
    midlands
    Quote Originally Posted by T4M View Post
    Just watch your nuckles. Got the missus to untwist mine(little hands)
    Larkhall
    I managed to slit my wrists on the driver one when fitting it for a customer......... guy gave me a good tip so it was worth it
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by ed taylor View Post
    Threads now merged.
  1. Replies: 13
    Last Post: 23rd March 2013, 23:10
  2. Changing NSF bulbs
    By ScottR in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2010, 22:26
  3. Front bumper removal, and changing indicator bulbs
    By baard in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2009, 18:00
  4. Changing front indicator bulbs
    By Keith Fusco in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2009, 21:16
  5. Changing bulbs.....
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2008, 14:30
