Thread: Disconnecting Battery
    Liverpool
    Default Disconnecting Battery
    Hope somebody can help, just done a airbox mod to my 2.0 dti veccy. I've heard that you need to disconnect the battery for some reason, something to do with the ecu. Does anyone know if this is true. if so, how do i disconnect it. cheers.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Just unplug the Neg for 15-20 mins mate. All it does is help the ECU to re learn any new parameters.
    Liverpool
    Will do, thanks very much mate.
    Regular Member craigmerry's Avatar
    Jan 2008
    midlands
    Does it really matter just for airbox mod ?
    Vehicle : SRi
    Mileage : 137000
    Wouldnt have thought so, but every bit helps.
    6 Post(s)
    Just make sure you have your stereo security code to hand before you disconnect the battery.
    Also, depending on how old your Vectra is, you will have to switch on then off your ignition and disconnect the battery within 15 seconds otherwise the alarm will go off.
  1. When disconnecting the car battery.......
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2009, 17:27
  2. Disconnecting the battery
    By badge25 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2007, 12:40
  3. Disconnecting battery...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2007, 23:06
  4. Disconnecting Battery
    By Neil in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2007, 18:12
  5. disconnecting the battery!
    By carl bear in forum Electrical & ICE (including SatNav)
    Last Post: 26th March 2006, 22:17
