Thread: lighter thing doesnt work
    Regular Member lilangel's Avatar
    bucks
    Default lighter thing doesnt work
    any easy thing that could have gone wrong? tried both my pogoalert and the satnav and none are being charged, is that a dealer job ot is there a possibility of something easy like a fuse? thanks!!
    Nicking Ya Dinner.
    Only works with the ign on.
    Chelmsford
    Get a small file or knife and gently scratch the contact at the bottom of the socket in the centre (make sure ignition is off or you'll need to do a new fuse too!). Mine didn't work until I tried this as the surface had corroded, now works perfectly. Hope that helps.
    bucks
    thnx, will try the knife technique tomorrow!
    Regular Member The Gas Man's Avatar
    Feb 2006
    north east
    knife worked for me also
    Aug 2007
    Leicester
    My satnav charger only works in a specific orientation and position when in the 12v socket. One in the rear is much better fit and works in all positions. I put it down to a crap sat-nav charger - only got two contacts on it.
    bucks
    tried the knife technique and still doesnt work, so tried the rear socket and that one doesnt work either.......whhhhhhyyyyy?
    Have you checked the fuse????
    bucks
    will do tomorrow, thnx )
    Always a good place to start, if its ok find someone with a multimeter or voltage indicator to check the sockets out and the supply to the fuse.
  1. radio doesnt work
    By mtqn in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2012, 02:40
  2. Cigarette lighter socket wont work with lighter
    By Aaron1990 in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2012, 18:21
  3. key fob on mk 4 astra doesnt work
    By tyler boy in forum The 'Off Topic' room
    Last Post: 2nd July 2011, 20:25
  4. Fan doesnt work on position 1
    By martinmack in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2011, 21:38
  5. car kit doesnt work since i changed hu?
    By EURO G in forum Electrical & ICE (including SatNav)
    Last Post: 5th April 2008, 17:19
