Thread: knocking from rearwhen braking?2007 28k
    Regular Member Craig1985's Avatar
    harwich essex
    confused knocking from rearwhen braking?2007 28k
    if moving forward or reverse and push brake pedal hard i get a knock from rear? rear wheel i think but cant pin point anything? neither can the stealers? vectra 1.9cdti 2007 reg wit 28k? any ideas would be gr8?
    Full Member Big Sig's Avatar
    If they have agreed there is a knock there i'd leave it to them to find. However its got to be a loose suspension joint of some form or part of the braking kit imo.
    harwich essex
    now im worried incase the calliper falls off of the sus leg falls off!!
    If your worried that may happen, jack it up, remove the wheel and have a poke around yourself. You'd be amazed what dealers miss sometimes.....
    South Central England
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Make sure the spare wheel and tools are secure
    harwich essex
    Quote Originally Posted by nutron View Post
    didnt think of that one i'll have a look....
    jacked up but couldnt find anything with play in it? so will now check boot
    Belfast
    Could be the pads moving about in the caliper?
  1. Knocking sound when braking
    By JezzerD in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2011, 20:44
  2. Knocking from front under braking
    By nick_s in forum Suspension, Wheels & Brakes
    Last Post: 30th March 2011, 20:23
  3. Knocking noise when braking!!
    By dave collingwood in forum Vectra C / Signum Troubleshooting
    Last Post: 8th May 2008, 07:53
  4. better braking
    By leeandjude in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2007, 20:46
  5. Knocking noise when braking?
    By karlp606 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2007, 12:29
