Thread: crank pulley problems help needed!
    Mar 2007
    dublin
    Default crank pulley problems help needed!
    Hi all
    Last knight while driving home heard a knock and then battery light came on so I guessed that the fan belt had snapped but it was the pulley.
    Are these a pig to get off and has anyone got a diagram of which way the belt goes on?
    thanks in advance
    yes, they are a bit of a pig...the centre bolt is very very tight...you need commercial grade air tools to get them off...
    also, i don't know what the parts supply is like in Eire, but the pulleys were on massive backorder..( who said it's a common fault)....
    Mar 2007
    dublin
    Does the engine have to be locked when using an air gun?
    My mechanic cant get the nut out with his air gun, says I might need to take the car to somewhere that changes the likes of truck tyres to remove the bolt.
    nope, you don't have to lock it, it's just that most 1/2" drive airguns won't touch it.. Benny on here uses a 3/4" drive gun... I had to resort to a 1" drive gun to get 'Bigmans' pulley bolt out... they are VERY tight..
    Mar 2007
    dublin
    cheers 1" gun had it off after 3 attempts cars all sorted now, 3/4 gun had no affect on it.
    Its a tight un, I was told that the toyota avensis diesel has a similar problem with the crank pulley but the bolt head nearly always shears off, ouch!
  1. 2.0DTi Crank Pulley !!
    By Led in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 17:55
  2. Crank Shaft Pulley???
    By Stephen S in forum Engine & Drivetrain
    Last Post: 1st September 2010, 20:27
  3. Crank Pulley Damper
    By KevinC in forum Engine & Drivetrain
    Last Post: 11th January 2008, 20:15
  4. crank pulley
    By andyc#elite in forum General Chat
    Last Post: 18th November 2007, 09:12
