Results 1 to 10 of 19
Thread: lamda sensor how 2?
    Regular Member Woodsta's Avatar
    May 2006
    Kent
    Default lamda sensor how 2?
    Hi all
    My exhaust gases light came on tonight, and i believe the first option is to change the lamda sensor.
    Is there a how 2 on here? if not any advice will be welcome.
    Woodsta
    Chelmsford
    If it's the same as the Vec B, it's a piece of cake. It will be screwed into the exhaust, just after the downpipe. Just a big spanner needed to unscrew it and then trace the cable back. The only difficult part is getting under the car in the first place (I'm lucky as my grandparents have an inspection pit which I use).
    Of course, if the Vec C is different then this is of no use at all so sorry but I'm no help! Now if they'd hurry up and release that ****** Haynes manual...
    May 2006
    Kent
    I have removed the plastic sump guard with its 50,000 torx screws!!!! but its got too dark too quick to have a look, yet another saturday under the siggy
    [Ex]Admin Duncan's Avatar
    Before you start buying and replacing parts - especially expensive one - the first thing I'd do is disconnect the battery for a bit and reset the light. Sometimes the warning light can be triggered when there's no real problem or faulty part - often if it's cold outside, resulting in the emissions to just for a moment be out of the expected range.
    If you do that and the light doesn't come back on again then nothing to worry about.
    yes, before changing the sensor, get it 100% diagnosed first...don't just guess it..
    May 2006
    Kent
    Hi
    I disconnected the battery for a good hour, the car and spanner went out but the exhaust gases light stays on?
    Oh god, how much is the sensor then? difficult job?
    VX cant fit me in till friday.
    I might try the other VX dealers to see if they can fit me in for tech 2.
    If not im in the works astra van for a while
    Wodsta
    Lamda's, from memory, are nudging the £100 point I think - maybe a little less. They're not cheap for sure. Easy to fit generally (not sure on the 3.2 specifically as I don't know if it's a begger to get access to it) - just not a cheap part.
    If the light is only on steady, then that's okay. If it starts flashing then that's not okay - you need to stop driving it or you're in danger of wrecking the cat.
    Best to get a Tech 2 to see what's being thrown up.
    May 2006
    Kent
    Hi Duncan
    I will wait for friday for the tech 2 at my local VX, they know my car very well. And i half trust them.
    I will have a quick look at it tomorrow, you never know it may be a poor connection or something silly?
    Fingers and everything else crossed!!!!!
    Cheers Mate.
    Woodsta
    Mileage : 000
    Yep I would get it checked out first. Too.
    If I am correct I am sure there are Four on the 3.2.
    Mark will put us right.
    May 2006
    Kent
    Mines only the 1.9 150
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
  4. lamda on 2.2 dti
    By mats13 in forum Engine & Drivetrain
    Last Post: 27th April 2010, 18:23
