Results 1 to 10 of 23
Thread: ecu problem
    newcastle
    Default ecu problem
    hi
    there I have just bought a vectra c sri 2.2 dti 2003 the first day i had it the spanner and car light came on when i took it to garage they said it needed a new thermosat and seal done .
    i got 5 mile down the road and light came on again took car back and they said it was turbo sensor pad which has now been replaced ive done 70 mile and light back on turned the car off light goes back off done 80 and nothing so it must not be serious problem car back in the garage on tuesday
    is this a common promblem with this model cos garage said this year of vectra and zafira have same problem or should i get rid of car only had car three weeks been in garage 4 times or will it be easy to fix any ideas
    any help thanks
    [Ex]Admin Duncan's Avatar
    I'd hazard a guess it's the ever common boost hoses - common problem on that engine. Check all the boost hoses, especially underneath, for the slightest of splits - that'll be enough to bring on the spanner light. I assume you had a big drop in power too?
    There's a modified hose (strengthened) available that is meant to reduce the chances of it happening again.
    HTH
    newcastle
    would that not pick up when they run the dianostics machine at the garge
    It should've logged some error codes, but it all depends how they've interpreted those. It may have been something like 'Boost out of range' and they've assumed it's a sensor, when what happens is that due to the pressure escaping through a split, the boost is increased as a sensor downstream detects a drop, but then when it's increased the sensor upstream goes "Wooah, too much boost" and logs and error and drops pops up a spanner.
    The fact that they've said you need a new thermostat due to a spanner light coming on makes me question their diagnosing abilities. I'm pretty sure a dodgy thermostat doesn't throw up a spanner light, although I may be wrong. Were there any symptoms of a dodgy thermostat? - engine temp not increasing, cabin cold etc. If not then why did they replace the thermostat.
    My money is still, currently, on the boost hoses. It would be good if you could find out what error codes were read off.
    newcastle
    i can try and find them engine temp was slow the car only seems to do it when going from 4th to 5th gear when u need it most and doesnt happen everytime so i could go to 70 easy then come all way back down the gears then back up and then then the spanner light on i thought the problem was on the computer itself the way it going
    The split hose issue is more likely to show it's symptoms when you're demanding more boost - so that could be in different gears but at low revs i.e. when the demand for boost is increased.
    Try it in a few gears to see if it does it in them. i.e. let the revs drop fairly low and then give it a bit of throttle to accelerate, this will cause an increase in demand for boost and will be the time when the problem is more likely to occur - if it's the split hose issue.
    newcastle
    well it booked in tuesday to be looked at agian il tell them to check all the hoses for any slits been dying to get a vectra sri for ages then when i get it nothing but bother so far never had chance to tart it up yet or give it a proper drive
    newcastle
    any 1 else got this model of vectra had the same problem
    have the actually given you the codes for whats wrong?..or are they guessing it?..
    it could be one of quite a few things to be fair..dirty boost sensor, dodgy vacumn solenoid and hosing.....
    If it's not been code read then nows the time...
    newcastle
    i have not had codes do you think if i take in to a kwik fit they will look at all the hoses for free how much will it cost to update the computer
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
