Thread: HELP front springs
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Default HELP front springs
    car in bits trying to get my new springs. Back ones are on OK.but the front. How do you get the top nut off. I've got a t50 bit but can get anything to hold onto the nut. Any suggestions please
    Cirencester
    you need an air gun with a 21mm hardned socket.
    even a 21mm drop spanner will no go in there, angle is to steep
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    You can use a 21mm ring spanner,just grind the back of it off until it fits.
    UK
    You could also use a Vortex Socket, I had to get one of these to do my front struts.
    UK
    Oh , and undoing it a little while its still connected to the car makes the job a little easier.
    Feb 2007
    Glasgow
    Quote Originally Posted by John35 View Post
    Yep, it's easier to loosen them when they're on the car, not all the way, though.
    If you're replacing the damper, you can grip the rod, through the spring, with a pair of mole grips, then use a socket on the nut. Not recommended if you're putting the same damper back on again.
    Jun 2007
    in a white box
    Quote Originally Posted by cookie View Post
    That man is a star. All fitted but needed some box spanners. Cookie you're a star..........
    Tyneside
    Just used an offset spanner to hold the nut when I done mine, worked fine.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    you could use a pair of vise grips on the shaft near the top and then undo the nut with a 21mm socket and ratchet
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    just did mine luckly loosened them whilst still on car no problems at all
  1. Are front springs different..?
    By Chunklamb in forum Suspension, Wheels & Brakes
    Last Post: 1st September 2012, 20:47
  2. front springs
    By porthy-t in forum Handling & Braking
    Last Post: 13th May 2009, 18:41
  3. front springs
    By iceeee in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2009, 09:25
  4. Front springs
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2006, 10:48
