Results 1 to 10 of 13
Thread: Aftermarket Headunit
    Regular Member mshaw's Avatar
    North Wales
    Default Aftermarket Headunit
    HELP!!!!!!!
    I have had my Pioneer headunit in my 53 Plate car for a while now, and i have just got round to buying a stalk adaptor.
    The problem i have is that when its plugged in it just doesnt work. I have spoken in-directly to Connects 2 and they have said that i have the Digital Steering wheel with the analog ISO plugs and there is nothing they can do to make this work. They said that my car is in a no mans land where they were just changing to the CAN-BUS system.
    Is this true? or has anyone else had this problem?
    Also i was thinkin that if my steering wheel controls are connected to an old plug then it must still only be one lead that i need to find to get these controls to work. Am i just talking crap or is this fixible.
    Please Help me!!! Its very annoying that i cant get this to work.
    SCOTLAND
    it is a minefield mate. mines is an 04 plate and i fitted a pioneer unit but have just used the remote that cae with it. Pioneers website says there is a lead but i have not gotten round to trying to find out for certain if it would work or calling them
    http://www.pioneer.co.uk/files/pdf/H...ptersChart.pdf
    Jan 2006
    Skynet HQ EMEC#5
    I fitted a Sony headunit to my 53 plate vectra, along with a Connects2 stalk & display adapter.
    To start with mine didn't work either. I then re-checked everything & found I had missed putting power feed to the connects2 unit.
    This may be something worth checking
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Quote Originally Posted by Ian T View Post
    i have an alpine headunit with the same setup and i had a problem at first powering it up but it just needed the live feed changing over
    North Wales
    So what did you do to get power to it, just feed it off something else. Its a nightmare, Does anybody have a sketch or know what each cable does on the third plug, the wider one.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Yep they are right, your car must be still half canbus and I could not find a working solution
    Feb 2006
    Guttedsville
    Fag lighter.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    was yours half or full canbus?
    11 Post(s)
    Quote Originally Posted by merikiito View Post
    53 plate Vectra will be halfcanbus.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    53 plate was the crossover period so it might have been full canbus which will work. If it was half canbus then I am going to be gutted as I could not get the steering controls to work on my old car
  1. The pros and cons of an aftermarket headunit
    By cont1204 in forum Electrical & ICE (including SatNav)
    Last Post: 27th December 2010, 22:39
  2. Aftermarket headunit wired to battery
    By tubby in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2010, 22:03
  3. Fed up - please help... Aftermarket double din headunit fitting
    By andyfeeny in forum Electrical & ICE (including SatNav)
    Last Post: 23rd July 2010, 19:42
  4. Vectra Aftermarket Headunit Help
    By jmacp in forum Electrical & ICE (including SatNav)
    Last Post: 18th May 2009, 21:35
  5. Aftermarket Headunit
    By bigdan in forum Electrical & ICE (including SatNav)
    Last Post: 19th December 2006, 21:56
