Results 1 to 10 of 16
Thread: Spanner light & ECU reset - 2002 GSi
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default Spanner light & ECU reset - 2002 GSi
    For a while now, my spanner light comes on momentarily and then goes off, so nothing to worry about (yet).
    When I did the ECU reset following the fitment of a Courtenay air filter, the spanner light stopped coming on for a couple of weeks. Then the light came on again (still momentarily) so re-set the ECU again just to see what would happen. Light then went out for three weeks. Just when you think all is OK, ****** thing is back again.
    Why would re-setting the ECU give me a "temporary" fix or is it just coincidence?
    it would give a temporary fix until the fault reoccured again... then it would leave the telltale for 25 odd restarts
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    Where abouts in London are ya mate?
    gonna make him an offer he can't refuse Dad..
    Regular Member Small Racer's Avatar
    Jan 2008
    Hampshire
    Is it the fault that is temp or the fix? The CAN OBD2 standard states that the fault will be recorded for 40 days then erased if the fault does not re-occur. So unless you keep a careful record of dates etc.. You will not know if the fault is a 'new' occurance or the old one at say day 38. So when you hook up to the ECU check the number and type of fault recorded before you reset and clear the faults it would appear useful to keep a record of the day you erased and a record of the number and type of faults you clear.
    or......when you actually log into the cars ECU.. you note the fault...select 'erase codes'.. select ' refresh list'... and it will tell you if it's still a live fault or not.....
    what i was saying is that if GTR disconnected the battery the ECU will 'forget' all faults till it reoccurs again, so giving a temp fix to the 'light on' issue, but not addressing the real root cause of the problem..
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Mark, do I need to get it tech 2'd at a VX stealer or butter someone up who's got a reader?
    i think a PM to Plasma would get you sorted as he's got the same kit as me and he's london based..
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Done, thanks mate.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Mark, I think Plasma's over Essex way, you might be a tad closer
  1. Spanner light.how do i reset?
    By Dobs in forum Engine & Drivetrain
    Last Post: 24th August 2012, 02:16
  2. Can the car/spanner light be reset?
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2010, 19:25
  3. spanner light reset emission light now on HELP!
    By johnny boy67 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2009, 12:07
  4. How to reset spanner light?
    By busterpoo in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd March 2009, 13:56
  5. Spanner Light - Does it need to be reset?
    By thompo5 in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2009, 05:56
disconnected battery to reset Ecu on vectra c gsi 2002
