Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Vectra VXR Front Brakes For Sale
    spoons
    Guest
    Default Vectra VXR Front Brakes For Sale
    Vectra VXR 345mm Front Ventilated Brakes including Calipers (Arden Blue), Discs & Pads.
    They were removed off my new Vectra VXR after 2000 miles (exchanged for the AP Racing 6-Pot Brakes).
    Perfect working order, no warping, no heavy use. Just taken off straight away within the first week of ownership.
    £550 plus Postage (remember these weigh a TON) so collection preferred
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    would they fit an sri 1.9cdti vectra?
    spoons
    Guest
    Quote Originally Posted by aerodynamic18 View Post
    They should fit yes. but... you need to check the alloy wheel offset (to make sure the calipers will fit behind your wheels)
    And, you will need to check that your brakes dont have the disk 'backing plate' as this may mean you need to change the hubs as well.
    Speak with Mark (GSi3.2) as he should know exactly whats needed.
    spoons
    Guest
    Bump
    Jun 2007
    Sittingbourne, Kent
    I would have had these , but am 90 % sure i ll be putting the GSi up for sale soon ...
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    I've just fitted the 314mm kit, gutted!
    spoons
    Guest
    Quote Originally Posted by Kev_A View Post
    ... then you'll just have to take them off again
    Nov 2007
    Lincs
    Sell me the 314s cheap and your on the ladder
    Regular Member DarrenLee's Avatar
    Shipley, West Yorkshire
    If I knew they fit my car I would make you an offer..... anyone know if they would fit my car???
    Dont scare me with technical questions to try and find out.
    if the offset on the rims is okay, then they will fit..you may have to trim off the balljoint heatsheild, but it will all bolt right on.....subject to the calipers clearing the rims..
  1. Vectra 2.8T V6 (250) front brakes?
    By the_rocker in forum Handling & Braking
    Last Post: 11th April 2012, 14:12
  2. 314mm Vectra c front brakes
    By marktaylor in forum Parts for sale
    Last Post: 31st March 2012, 13:22
  3. vectra vxr front and rear brakes
    By tbs in forum Suspension, Wheels & Brakes
    Last Post: 10th March 2009, 22:43
  4. 314mm front brakes for sale
    By amar in forum Parts for sale
    Last Post: 10th June 2008, 14:33
vauxhall insignia vrx 345mm brake
https:www.vectra-c.comforumshowthread.php42772-Vectra-VXR-Front-Brakes-For-Salevectra vxr brakes for salevectra vxr front brakes site:www.vectra-c.com
