Thread: Estate Rear Camber Adjustment
    Regular Member installer's Avatar
    Nottingham
    Default Estate Rear Camber Adjustment
    Can it be done on an estate?
    Have read that can be done on hatch.
    Mine is an SRi if makes any difference-wouldn`t of thought so.
    Is £40 a good price for 4 wheel alignment.On that site that GSi recommended?
    Hunter machine.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    £40 sounds good as I was quoted £65 plus vat at an alignmycar place near me.
    Did you fit the bushes in the end as I bought some today as the dealers couldn't find anything wrong even though they heard the noise. Apparently they lubricated the bush.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    when you go and get it done watch them if you can as most tyre centres say a 4 wheel alignment and only adjust the fronts.
    when they have adjusted the front first they should then but the front gages on the rear and the rear on the front
    Nottingham
    Quote Originally Posted by John35 View Post
    No they are still in the packet.Mechanic friend said he would be gobsmacked if it was bushes on a 3 1/2 year old car at 30k.
    So we greased the front pan with copper slip and checked the spring and spring mod and so far,it`s been quite as a mouse.Can just hear all the rattles at rear now.
    But we will over haul both front struts and fit new spring mods in summer and clean and regrease it all.
    Jun 2007
    in a white box
    I wasted £5.12 then........
    Going for a quick drive tomorrow morning to see if its fixed. Fitting my eibachs friday so will have a look as well to see how easily they can be changed.
    Nottingham
    Look not to hard to do if a little fiddly and time consuming.
    Also oiled rad mounts at same time to.
    Jun 2007
    in a white box
    Will be oiling my rad mounts as well............
    Quote Originally Posted by installer View Post
    Hunter machine.
    sure can be done.. the subframes are near on identical, so all the adjusters are the same...
  1. Camber adjustment?
    By Neil07D in forum Handling & Braking
    Last Post: 22nd January 2012, 11:20
  2. Rear Camber Adjustment
    By spoons in forum Handling & Braking
    Last Post: 10th November 2010, 22:00
  3. Camber adjustment bolts
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 09:23
  4. Location of Adjustment Points For Rear Camber
    By marcdale in forum Suspension, Wheels & Brakes
    Last Post: 30th May 2008, 09:29
  5. camber adjustment
    By hagga in forum Handling & Braking
    Last Post: 12th November 2007, 15:45
