Thread: Turbo Wastegate Solenoid 2.0DTi
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    Default Turbo Wastegate Solenoid 2.0DTi
    Is this solenoid supposed to be noisy, as mine sounds like there's a ball bearing spinning around in it. It doesn't appear to be creating any problems, but I'm just curious...
    it shouldn't make any noise at all...
    remove the boost hoses and check the impeller shaft for any 'wobble' there shouldn't be any..
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    Thanks for the response, but the solenoid has two narrow pipes going into it and lives to the left of MAF, so I assume these are what you call the "boost hoses", but isn't the impeller shaft part of the turbo ????
    they are the vacumn hoses...and yes.. that solenoid will make a little noise..
    it the wastegate makes any noise take the turbo's boost hoses off to investigate the impeller
  1. Signum turbo wastegate help
    By redryan in forum Engine & Drivetrain
    Last Post: 18th February 2013, 21:46
  2. Signum 2.8 turbo wastegate actuator
    By viper8 in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2012, 08:22
  3. Turbo boost solenoid part nos 2.0t
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2011, 12:53
  4. Fault code P0243 (1.9CDTI 150) Turbo wastegate...
    By danBoy in forum Engine & Drivetrain
    Last Post: 4th December 2010, 15:45
  5. Replies: 5
    Last Post: 15th January 2009, 19:08
adjusting the waste gate on a vectra 2.0 dti
vectra 2.0 dti wastegate
vectra dti adjusting wastegate site:www.vectra-c.com
