Results 1 to 10 of 16
Thread: Alternator question
    Regular Member siross's Avatar
    Oct 2007
    Default Alternator question
    Hi,
    I am about to embark on quite a large system for my vetra, its a 1.8 sri.
    Is there a bigger/more capable alternator that would fit, say off one of the diesel models? And if so how hard are they to fit?
    Simon
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Don't quote me on this but i'm sure the original is upto the job.
    I had a new alternator fitted to my last car (cdti 150) as it'd blown the diode. The RAC guy who towed me to the garage said that the alternator only runs when the ECU tells it to. In other words, if the battery starts to get low on power ,the ECU will start the alternator until the battery is fully recharged.
    My guess is if you run a system that takes loads of power, the alternator will just run more often.
    Mileage : 55000
    But will it be able to keep up with the output when say all the electrics are on "ie" heated window blower all the lights and "the music".
    Regular Member scottyd's Avatar
    paisley
    just get highest amps alternator that wil fit try phoning lsuk for advice
    Oct 2007
    Has anyone tried fitting a new alternator?
    The alternator will power the system but thats not the issue, i dont want any voltage drop! Dimming lights when going loud etc
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    Think basic one is 100 amp but there is a 120 amp.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If you don't want dimming lights on loads of bass, you are looking at the wrong part - ie alternator. At really high transient loads, the alternator will not be able to put enough in, even if you go for the biggest one that will fit. You need to fit a bigger capacity battery too.
    Go for the diesel battery, I would have thought that the constant charging of the alternator would be fine as standard, but it might wear out quicker due to higher duty cycle factor.
    ECU controlled rotating electrics is new on me. I changed my brother in laws Astra 52 reg diesel alternator the other night, and there was certainly no control over it by the ECU.
    Alternators don't charge the battery when it is full anyway, it's the nature of how they work that does that, not control by the ECU.
    I could be wrong, but I can't see how / why VX would add that complexity when it really isn't needed.
    Vehicle : SRi
    Mileage : 110000
    I though the alternator ran all the electrics once the car was started so in effect its always working.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    There will be times when the electrical load is very low, and the battery is topped up fully. But essentially yes, the ALT powers the cars electrical system all the time and keeps the battery full (aims to anyway)
    Oct 2007
    a bigger battery and upgrading the big three are also on the agenda, what's the difference beteen the diesel batt and the one I will have? also im guessin vauxhall don't sell these particularly cheap?
  1. Alternator question...
    By Chunklamb in forum Engine & Drivetrain
    Last Post: 5th January 2013, 23:02
  2. alternator
    By reeseandellie in forum Engine & Drivetrain
    Last Post: 21st January 2012, 12:21
  3. alternator
    By hitcho in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2010, 21:01
  4. Alternator
    By satbeychap in forum Engine & Drivetrain
    Last Post: 24th December 2009, 23:49
  5. Another alternator question
    By parsco in forum Engine & Drivetrain
    Last Post: 26th August 2009, 12:32
alternatorquestion
